B300 King Air grief
B300 King Air grief
Postby tor lives » Wed Aug 03, 2016 6:08 pm
This is not good for King Air operators.
http://www.couriermail.com.au/lifestyle ... 910d003d7b
Re: B300 KingAir grief
Postby davecana » Fri Aug 05, 2016 10:37 am
They're starting to come back on line. A32-349 was up and flying yesterday.
davecana
Postby Graeme H » Fri Aug 05, 2016 1:22 pm
yes getting sorted, can't find out if it is only the RAAF ones. or are some civil ones also affected.
Postby tor lives » Fri Aug 05, 2016 10:16 pm
Graeme H wrote: are some civil ones also affected.
I am hearing through my industry contacts that there may be several VH-registered aircraft so far affected.
Postby tor lives » Fri Aug 05, 2016 10:18 pm
davecana wrote:They're starting to come back on line. A32-349 was up and flying yesterday.
Where the drivers holding their breath just as a precaution :D :D
Postby scotty100368 » Fri Aug 05, 2016 10:56 pm
Eh, just stay below 10,000 so you can open a window! ;)
Scott.
Postby BradG » Sat Aug 06, 2016 12:26 am
So who's been sanding parts with primer on them? It's kinda like the F-111, the cockpit module we have at Moorabbin is leased to the museum under certain guidelines, one is we cannot sand the surface as the metal powder you produce is carcinogenic.
Postby tor lives » Sat Aug 06, 2016 10:16 am
I would be interested in what Hawker Pacific has to say about this.
Re: B300 King Air grief
Postby davecana » Sat Aug 06, 2016 7:48 pm
It is a from new problem. The bypass valves were painted internally. When the contamination was found, it was the first time that these valves had been removed since the planes were new. Some spares were also inspected and found to be also painted internally. It has nothing to do with sanding paint, the engines aren't running when any sanding is done. The contaminated part is in the pressurisation line, bypassing the cabin air around or through a cooler, depending on temp selected. There is no contamination between the valve and the engine, but contamination from the valve into the cabin.
davecana
