Best way to cut brass rod?
Postby Tony P » Fri Aug 08, 2014 5:00 pm
Hi all,
What's the best way to cut brass rod? It's about 2mm in diameter. I need a clean cut, if I use side cutters it pinches the rod. I'm assuming a saw of some description would work? Would a cutting tool on the dremel suffice?
Look forward to your responses.
Thanks
Re: Best way to cut brass rod?
Postby Cap'n Wannabe » Fri Aug 08, 2014 5:11 pm
There's a couple of ways I do it..
One is to use the cutting tool. Make sure you clamp the tube securely beforehand, though..
The other is to use a hobby knife. Place the knife in position on the tube, and push is back and forth. Allow the tube to roll with the motion of the knife. Takes a while, but gives a nice clean cut with a bit of practice.
Postby Knotty » Fri Aug 08, 2014 8:51 pm
What Damo said Tony , on small stuff it works great . Bigger stuff you may require a tube cutter from Bunnings or some where .
Postby RayS » Sat Aug 09, 2014 8:21 am
I use my trusty razor saw to cut brass tube.
Just take it easy and apply light pressure and you won't deform the tube
Postby Tony P » Sat Aug 09, 2014 1:35 pm
Thanks all. Appreciated.
Postby AndrewDoppel » Tue Aug 12, 2014 8:28 am
Spotlight have tube cutters in their curtain section for about $13 which would also do the job. Bought one recently and works a treat on tubing but don't know how it would go on solid brass.
Postby Night-Raptor » Thu Aug 14, 2014 9:17 pm
Jewellers Saw - available pretty cheaply, and is good for plastic, metal, wood - pretty much anything :)
Night Raptor
Because after dark - everything looks good with Tiger Stripes.....
Night-Raptor
