Alternate Primer
Alternate Primer
Postby hrtpaul » Fri Jun 27, 2014 2:33 pm
Hey peeps. I usually use the Tamiya grey or white primer on my models but I can't get it in Townsville at this point in time. Does anyone know of any other primer eg automotive that I'd be able to get locally from maybe Supercheap etc? I'm using both Lifecolor and Humbrol paints. Ta in advance :)
Re: Alternate Primer
Postby davecana » Fri Jun 27, 2014 5:19 pm
hrtpaul wrote:Hey peeps. I usually use the Tamiya grey or white primer on my models but I can't get it in Townsville at this point in time. Does anyone know of any other primer eg automotive that I'd be able to get locally from maybe Supercheap etc? I'm using both Lifecolor and Humbrol paints. Ta in advance :)
I don't use any primer and have never had a problem. I paint with Humbrol and Testors enamels, and Gunze and Tamiya acrylics.
davecana
Postby _BlackHawk_ » Fri Jun 27, 2014 5:45 pm
Yeh just wing it, you'll be fine.
Postby hrtpaul » Fri Jun 27, 2014 6:19 pm
I like to prime so I can find and f*^% ups I've made like seam lines etc mainly :)
Postby F-27pax » Sun Jun 29, 2014 11:33 pm
I've taken to using primers all the time in the past couple of years and like to use Tamiya rattle cans too. A few weeks back I was in an automotive paint shop and bought a can of Motorspray Acrylic Primer Surfacer which is a lot bigger than a Tamiya can, is cheaper and doesn't seem too bad. But I don't know that I want to subject a model I've slaved over to something that might prove to be poor quality in the longer term, so I haven't used it much.
Postby hrtpaul » Mon Jun 30, 2014 9:42 am
Ta mate. I was thinking of going along those lines. I've got the perfect models to try it out on here so I'll give it a crack and see what happens :)
Postby Tony P » Mon Jun 30, 2014 1:04 pm
I've changed to Mr Surfacer 1000 & 500 in the spray bombs. I like it better than Tamiya. The 500 is good for resin, white metal and any major conversions where a lot of sanding was done. Use 1000 for priming a kit that needs no clean up.
Postby hrtpaul » Mon Jun 30, 2014 7:39 pm
Unfortunately mate I can't get that here in TSV either :(
Postby davecana » Mon Jun 30, 2014 11:56 pm
Paul,
Another alternative to primer, if your just looking for surface defects, is to use flat white in either acrylic or enamel, depending on what your top coat is going to be.
davecana
Postby hrtpaul » Tue Jul 01, 2014 8:02 am
Good thinking Dave :) The reason I use the Tamiya one at home is that I can then use any paint over the top and not have to worry about compatibility issues between the different paints :)
