Paging 727 modellers
Postby hrtpaul » Fri Jun 13, 2014 7:00 pm
Hey peeps. I'm currently doing a 727 that'll be a TAA or Ansett machine. The question I have is how do you guys put the stripe decals around the engine? I did think of putting the decals on first and then the engine but then i'll be left with a gap that I'd normally fill between the engine pylon and the fuse. On some schemes I'll have the same dilemma with the horizontal stab. If the solution is gonna require any sort of modelling skilll I might have 6 Airfix 727s' with decals for sale LOL TIA
An example of what I mean
Re: Paging 727 modellers
Postby _BlackHawk_ » Fri Jun 13, 2014 7:15 pm
That's easy, just paint it on.
Postby Capt NG » Fri Jun 13, 2014 7:17 pm
I decal then put engine on Paul... Making sure of course first that she fits like a finger in the proverbial... Sorry, probably doesn't help..then again, I'm not trying to be worlds greatest modeller either.
Postby _BlackHawk_ » Fri Jun 13, 2014 7:24 pm
The only other option left is to carefully cut the decal and lay it on around the engine. Measure twice, cut once!
Postby hrtpaul » Fri Jun 13, 2014 7:26 pm
Thanks guys. Seems I maybe stuffed on this one :cry: :cry: :cry: Back to building stuff that blows stuff up me thinks :oops: :oops: :oops:
Postby _BlackHawk_ » Fri Jun 13, 2014 7:29 pm
Nah just dive in. If I was going to use the decal I'd go for cutting it up.
Postby Knotty » Fri Jun 13, 2014 7:33 pm
Give it a crack Pual , like Stu said mate ......just sand the pylongs so they are a really good fit , and then stick the donks on . :o :o
Postby hrtpaul » Fri Jun 13, 2014 7:33 pm
Not enough room for error for me Brad. I'll continue to butcher (*puts on blue and white apron*) these nacelles to try to get em to fit better. At least it's not an expensive kit if I screw it up :)
Postby hrtpaul » Fri Jun 13, 2014 9:11 pm
I think I've sorted the engines and the tail. It's close enough for an airliner. They're just sitting on at the moment. Just gotta do the wing fences and then she'll be ready for primer :)
Postby Cap'n Wannabe » Fri Jun 13, 2014 9:15 pm
Looks good, Paul..gonna start mine soon..
