Revell 1:144 A380
Re: Revell 1:144 A380
Postby Graeme H » Mon Apr 20, 2015 8:30 pm
If you are interested I have a spare set of the 26Decals, it is the first issue and only has -OQA "Nancy Bird Walton"
This of course is the famous QF32 aircraft that had a small problem on take off from Singapore.
will sell for $15
The upside to the new Hawkeye set is that it has the best detail set, in that Scotty captured the inspar area in the correct shape, which is quite complicated, but you will need to fill all the incorrect lines Revell have engraved on the wings.
I guess as it is a commission build, do you really care about total accuracy that much?.
Postby Cap'n Wannabe » Mon Apr 20, 2015 8:31 pm
hrtpaul wrote:OK that's enough talking about the best aircraft in the world. Back to Troy's QF pregnant hippo ;) ;) ;)
Must have missed it....I don't recall *any* mention of the Piper Aztec..
Postby RayS » Mon Apr 20, 2015 9:01 pm
The 'new' CDS111:QANTAS A380-800 Delivery Scheme
Postby tor lives » Mon Apr 20, 2015 9:13 pm
That's great Ray.....thanks for posting. Just out of curiosity, when was the revised CDS111 released???
Postby scotty100368 » Mon Apr 20, 2015 9:56 pm
Hi Guys! - I've been catching up on sleep this arvo (shift-worker) and just saw the post.
I actually did a slight update and correction for this sheet back in January...
Updated fleet info...
Window config detail unchanged (from first release) ...
And decal sheets (fixed the shaping of letter D in the regos)...
Scott.
Postby tor lives » Mon Apr 20, 2015 10:10 pm
Thanks for that Scotty. Is your newest incarnation of the A380 sheet still the same CDS number???.
I will need one of the new sheets because I have a plan to do a diorama of "Nancy" sitting on the ground back in Singapore, all banged up on that fateful day. While I think it is fair to say that I am not an Airbus fan, "Nancy" certainly earned my respect.......she got her crew and passenger home safely under the most extraordinary conditions of damage imaginable, and you can't ask for more than that from any aircraft.
Postby DesTROYer » Mon Apr 20, 2015 10:36 pm
Graeme H wrote:If you are interested I have a spare set of the 26Decals, it is the first issue and only has -OQA "Nancy Bird Walton"
will sell for $15
Thanks Graeme. I'll be in touch. It's for a 6 year old to hang from the ceiling, so accuracy isn't a primary concern, but I do want to do a good job as far as seams and paint goes.
Postby DesTROYer » Mon Apr 20, 2015 10:37 pm
Those Hawkeye decals sure a a work of art Scotty.
Postby scotty100368 » Mon Apr 20, 2015 10:45 pm
TOR,
I just spoke with Peter and he said that he now uses CDS-111 for this correct version. The old (proposal) scheme is still available on request however.
Scott.
Postby Graeme H » Tue Apr 21, 2015 6:50 am
DesTROYer wrote:Thanks Graeme. I'll be in touch. It's for a 6 year old to hang from the ceiling, so accuracy isn't a primary concern, but I do want to do a good job as far as seams and paint goes.
Not sure if you have done anything with long seams before, but in case not, then superglue is your friend.
My method, others may chip in with different ideas
I usually use MEK (Bunnings plumbing dept) start at the fin then work my way along the top first, as it is the longest and hardest one to do, you get a small amount of working time with MEK, but not much.
I tape up the nose below the windscreen where the glue won't go to hold it together a bit, essential you remove the tape before you go onto that bit.
It is essential you use a small brush to put on the MEK as it is very viscous and will go everywhere, it's the less is more theory.
When that has set up (15 minutes) I then run superglue down the seam on the inside, before doing anymore, let that go off, if you think it is going to go where you don't want it use accelerator.
I will then go around the nose, then along the bottom, this can often take a couple of hours, but if you are careful you will get a seam that will need very little filling, depending on the kit I can often do around aerials without needing filling.
Remember there are a lot of gaps where you can do up to without the glue getting too far ahead of you, the reason I use MEK is that the bond is very quick, less than 2-3 minutes, then superglue on the inside (you can also use epoxy) will ensure the seam won't later split on you.
a lot of people use strips of plastic card across the seam, I feel that the superglue is more than enough, I have dropped kits (yeah I know I'm very clumsy), and never had a seam split.
My personal preference is to use superglue on the outside of the seam as well, especially if you are doing anything with a natural metal finish, as Alclad and such can't tell the difference between superglue and plastic, not that there is much of that on an A380.
Interested in what others do.
