Paging 727 modellers
Re: Paging 727 modellers
Postby RayS » Sun Jun 15, 2014 2:49 pm
frediv wrote:Hi Paul,
Probably too late now but a simple method of obtaining a (near) perfect fit between pylon and fuselage is to place a strip of Sellotape over the area of the engine (before painting naturally) to act as a release agent. Coat the inboard edge of the pylon with bog and press the pylon up against the fuselage and hold in place until cured. When cured, the bog should have replicated the fuselage contour. Remove the tape! This method can be used to bypass any fiddling that may have been required. It can also be used for matching nacelles to wings, etc.
I'm finding it difficult to picture this, where are you putting the tape, on the pylon part of the engine assembly? And where does the bog go?
Postby hrtpaul » Sun Jun 15, 2014 4:37 pm
You put the tape on the fuse where the engine will sit. Then put the bog on the pylon and push the engine to the fuse and position the engine where you want it. The excess bog squeezes out as it takes the shape of the fuse where you first put the tape. Hope that explains it ok for ya Ray :)
Postby Night-Raptor » Sun Jun 15, 2014 6:58 pm
So bloody simple it is scary..... got to give this a bash!!
Night Raptor
Because after dark - everything looks good with Tiger Stripes.....
Night-Raptor
Postby RayS » Mon Jun 16, 2014 10:36 am
hrtpaul wrote:You put the tape on the fuse where the engine will sit. Then put the bog on the pylon and push the engine to the fuse and position the engine where you want it. The excess bog squeezes out as it takes the shape of the fuse where you first put the tape. Hope that explains it ok for ya Ray :)
Thanks Paul,
Clears it up nicely, currently working on an Airfix 727 so I will give it a go
Users browsing this forum: Baidu [Spider] and 12 guests
