I would like to build a KC-30
Re: I would like to build a KC-30
Postby Ansett A330 » Fri Jun 22, 2018 10:16 pm
DesTROYer wrote:I have found a tail conversion for the 300 to 200
The PAS Decals conversion?
Postby Ansett A330 » Fri Jun 22, 2018 10:21 pm
RayS wrote:On top of all that the kit needs to be shorted to an A330-200 (you can find instructions to do this on various forums for the location of cuts and how much to remove)
From memory :
A330-300 is 6 windows forward and 4 windows aft.
A340-200 is 4 and 4 (which by simple engineering is probably why it didn't need a new tail!).
Postby DesTROYer » Sat Jun 23, 2018 8:27 am
Thanks to Russ French, I have secured a set of refueling pods, tail boom and other lumps and bumps. The tail as I said earlier I have found on eBay. Decals may be a job for my portrait cutter when the time comes.
Postby DesTROYer » Sat Jun 23, 2018 8:30 am
Yes. Is that ok?
Postby DesTROYer » Sat Jun 23, 2018 8:35 am
Ansett A330 wrote:
DesTROYer wrote:I picked up a A330-300 kit on eBay this morning for only $23.00 delivered
Are you sure that is the kit or just a decal?
EDIT :
Wasn't this was it?
https://www.ebay.com.au/itm/Thai-Airway ... SwUKxYe8W1
Ah f#€£!
Postby Graeme H » Sat Jun 23, 2018 1:26 pm
There is this one still open for bidding from Bulgaria
https://www.ebay.com.au/itm/Revell-kit- ... SwtH9bJsVh
This boxing has both engines
Wouldn't go crazy on the price though, bidding gets frantic in the last 5 minutes, ask Ansett A330
As an alternative you can always use an A340, just need 2 GE Engines for it, either from an A330 kit or resin ones, the plastic is basically the same.
Postby hrtpaul » Sat Jun 23, 2018 4:53 pm
Couldn't Troy just use the kit etc he already has and buy some resin GE engines?
Postby RayS » Sat Jun 23, 2018 6:10 pm
hrtpaul wrote:Couldn't Troy just use the kit etc he already has and buy some resin GE engines?
Ahh, he doesn't have a kit, he has bought a decal!
The A340 idea is a good one, they may be easier to find. I can't believe the prices on eBay at the moment for A330 and A340 kits.
Postby hrtpaul » Sat Jun 23, 2018 6:12 pm
Oh shit. I get it now :o :o :o :o :o
Postby Ansett A330 » Sat Jun 23, 2018 10:04 pm
Yes. Is that ok?
Haven't seen one in the flesh but it certainly looks the part from the photos ...
