A couple of C-130s (C-130A Firebomber and HC-130N)
Postby RayS » Thu Mar 23, 2023 9:21 am
I have been tinkering away at these for a little while, they are both original tool Airfix kits.
The first is a C-130A firebomber for the Angels of Mercy display (if it happens) which I started a while ago (green plastic). Originally I was not going to do much with the flight deck.
But then I was given a part-started kit and decided to fill the flight deck out, the second kit is the mustard plastic which had been started to be converted to an AC-130A
I added cabinets and consoles from scratch using a DekLs C-130 interior decal sheet that had templates to make these up, of course, the Zvezda kit includes these parts so you don't have to make them. I also replaced the instrument panels with spare Italeri items and make new control yokes.
The C-130A buttoned up and some filling done
The second will be an HC-130N which is a Combat SAR aircraft or as the USAF website puts it 'dedicated fixed-wing Personnel Recovery platform' in an early livery.
I am also using Italeri props for the HC-130 and kit props for the C-130A. You can see the difference in shape here. They have been modified to fit the Airfix wing and still be rotatable
I am using the wings from the first kit on the HC-130 as the fuel tank slots had been filled on the HC-130's kit wings, wings are now on the HC-130, and some more filling is to be sanded away
Putty tidied up, rear control surfaces fitted and props test fitted
Re: A couple of C-130s
Postby tor lives » Fri Mar 24, 2023 8:42 pm
Very cool Ray, (and yes, the display will happen, it's just slid a year).
Postby BradG » Fri Mar 24, 2023 11:25 pm
Damn that's nice work there.
Postby RayS » Sat Mar 25, 2023 10:39 am
Thanks guys, I suppose both are eligible for the Angels of Mercy display since the HC-130 is a rescue aircraft.
The gear legs are on along with some more filling and sanding, and some future is on the clear parts in prep for masking. antennas are next and them some paint.
Postby RayS » Mon Mar 27, 2023 11:21 am
Masking complete on the HC-130 and some antennas and pitot tubes added
Paint started along with some more filling
Priming found some issues which were puttied and the main colour was added after masking the yellow sections. Not sure about the colour though
Repaint of the props is also underway
Image72_HC-130N_USAF_50 by Ray Seppala, on Flickr
Postby hrtpaul » Tue Mar 28, 2023 5:34 pm
Great work there man :)
Postby RayS » Sat Apr 01, 2023 4:15 pm
I repainted the old bird with something more appropriate to the correct colour and did some masking to add a splash of other colours.
Some tidying up to do now.
Postby hrtpaul » Sat Apr 01, 2023 6:02 pm
That's coming along nicely mate :)
Postby RayS » Sat Apr 08, 2023 9:57 pm
Some more paint on and now I need to figure out how to make a guide that lives on the upper ramp door
Postby hrtpaul » Mon Apr 10, 2023 10:23 am
Nice work as usual. Geez it's a big bit of plastic :o :o :o
