Airfix Fokker F-27-500 LADS **Finished**
Postby RayS » Sat May 01, 2021 3:28 pm
Next on the bench is the Airfix Fokker F-27 converted to a Laser Airborne Depth Sounding aircraft operated on behalf of the Royal Australian Navy.
I will be using a Hamilton Hobbies conversion as well as some replacement white metal under carriage legs.
Decals are from Southern Sky
From Wiki
The Laser Airborne Depth Sounder (LADS) Flight was a unit of the Royal Australian Navy. Unlike the rest of the flying units of the RAN, it was not controlled by the Fleet Air Arm from HMAS Albatross (NSW), but instead fell under the operational control of the Australian Hydrographic Service at HMAS Cairns (QLD), providing a platform for the operation of the laser airborne depth sounder system. in 2009 the F-27 was replaced by a DHC Dash 8 which operated until 2019.
I spent a few hours this morning making a start on the F27. The conversion includes parts missing from the Airfix kit like intake scoops and a couple of fairings at the rear of the horizontal stabs. You also get a replacement tail fillet, MLG legs and wheels (copies of the ESCI kit parts) and the fuselage plugs to make the -200 into a -500.
The parts were separated from their pour blocks and cleaned up
I also have white metal gear legs which are also copies of the ESCI which I will use instead of the resin parts
It was then time to do the surgery on the fuselage making the cuts and removing the undersized tail fillet
My preferred method is to use Dymo label tape to mark the line, scribe a line as a guide for a razor saw and then to finish off making the cuts with the saw.
I glued each subassembly together and then started to connect the parts
Some putty added, which was sanded
Which was sanded and round two of putty going on, this time also puttying the cabin windows as they are undersized and I will be using decals anyway.
Re: Airfix Fokker F-27-500 LADS
Postby F-27pax » Sun May 02, 2021 10:54 am
I'm looking forward to seeing progress on this one, it should look excellent.
Postby RayS » Sun May 02, 2021 12:27 pm
Thanks Leigh
On to the white metal gear, I had to modify the mount holes of to take the ESCI part copies
I also got the flying surfaces assembled
And initial sanding priming and refilling done, I also added the rear door. I'll add the nose and front door once I figure out how much nose weight is required.
Postby RayS » Sun May 02, 2021 9:35 pm
So I jumped ahead a little this arvo, most of the sanding a filling and the the major assembly done bar the nose cone. I also added the resin intakes down the back on both sides which replaced the moulded on one in on the kit.
Now to figure how much nose weight required... about this much.
I left the front entry door and nose cone off to allow it all to go in. Now to fit the nose which is way over size and has the wrong profile if you build OOB. I started another F27 kit soon after the last issue was released which has been a primary fixture one shelf of doom for some time (well 11 years in fact).
Here is the stalled build with my current one, I hope to finish it along with this one now. One thing that did bug me were the overly thick pitot probes on the wings, so they will be replaced with some tube on both F27s.
Here is a shot of how much the nose can be brought down to correct the shape as the retooled nose plastic is so thick (picture from my older build).
Postby RayS » Tue May 04, 2021 12:26 pm
The nose has gone on the F27-500, all I can say is what were the tooling guys thinking! Such a mess.
After a little time with putty, files and sandpaper it becomes presentable.
And then I added the LADs specific fittings
Postby scoops » Thu May 06, 2021 11:03 pm
nice work Ray,
How would one be able to get one of these kits or have i missed one.
I'm looking at making it in 1/144 as i already have the decals.
cheers
Sean C
scoops
Postby RayS » Fri May 07, 2021 8:07 am
Cheers Sean,
I got this set about 10 years ago now, it is long OOP. It was made by a fellow in Sydney. If you are on Facebook you can look up Hamilton Hobbies and send him a message to see if he still has the moulds. Pretty sure he has not done it in 1/144.
Time for some antennas, I grabbed a couple of towel rails from the spares box (Ex-C-130) and modified to suit
Added a couple of HF wire posts to the forward fuselage
and installed more bits and pieces underneath which all needs a clean up once the paint sets
Postby tor lives » Sat May 08, 2021 4:44 pm
Really interesting and educational so far Ray.
Thanks for posting.....you are essentially providing me with a "step-by-step" for my Fairchild/Hiller FH-227 project.
Postby hrtpaul » Sun May 23, 2021 11:06 am
Nice work there Ray. And OMFG that nose :D :D :D
Postby RayS » Tue Nov 26, 2024 8:30 pm
I'm dragging this one out of the dark ages, time to finish it up.
Since the last update 3 years ago I had been priming it and sorting out seam issues. Last week I managed to get a good base coat on it.
Today, before heading out ton the garden to do some upkeep I managed some masking and laying down the first colours
Next will be masking up the leading edges so the wings can be painted. I was worried the remaining parts of the build may have disappeared after a couple of moves but they were found and accounted for along with the decals.
