Revell 1/144 CargoLux 747-8F on the bench
Postby Fuzznoggin » Mon Feb 08, 2021 11:40 pm
I dove into this build with aspirations of only adding aftermarket flaps but ended up installing lighting and modifying the landing gear for an "over the threshold" runway diorama. Might have cut off a bit more than I can chew but the end result should look rather good. Led sizes vary from Pico, Nano, 1.8mm, and 3mm. Circuit board provided by Evan Designs. Final paint mix is Tamiya sky grey with white. I apologize in advance for just showing links as I cannot figure out how to display the images directly to the board. I'll put up more photo links as work progresses.
Image63380600135__78F63733-365A-4228-9709-11988A25B08C by Fuzznoggin, on Flickr
Engines
ImageIMG_E9488 by Fuzznoggin, on Flickr
ImageIMG_E9491 by Fuzznoggin, on Flickr
Wing cut outs, test fits with landing gear
Image63301884551__23B39C78-FEB5-4769-9264-F3B66881D17E by Fuzznoggin, on Flickr
Image142100582_3713355838699498_1184903112923661226_n by Fuzznoggin, on Flickr
Imageimage1 by Fuzznoggin, on Flickr
Aftermarket Flaps
ImageIMG_9622 by Fuzznoggin, on Flickr
Test fitting Krueger flap
ImageIMG_9615 by Fuzznoggin, on Flickr
ImageIMG_E9613 by Fuzznoggin, on Flickr
Fuselage guts
ImageIMG_9610 by Fuzznoggin, on Flickr
Beacon / Strobe flash rate test
ImageIMG_9597 by Fuzznoggin, on Flickr
Current Build - Aurora 737 refurbishing to JANET Airlines
Fuzznoggin
Re: Revell 1/144 CargoLux 747-8F on the bench
Postby RayS » Tue Feb 09, 2021 8:52 am
You certainly have dived in. The mods and electronics look very effective. Did you manage to find a grey for the scheme?
Postby Fuzznoggin » Tue Feb 09, 2021 9:30 am
RayS wrote:You certainly have dived in. The mods and electronics look very effective. Did you manage to find a grey for the scheme?
Yes. I did a custom mix of Tamiya Sky Grey with White in a large bottle. It's about as close as possible. The engine photos show the result. CargoLux was kind enough to get back to me and said it was Boeing Grey. Canadian Voodoo Grey is the closest but so very hard to find. So I took some paint samples I found online and came up with a close custom mix.
Fuzznoggin
Postby RayS » Wed Feb 10, 2021 6:31 am
Nice to see you found the colour, A company here called SMS does Boeing Grey in their range, they have a point of sale in the USA, one in Florida:
USA Gundam Store
(US DISTRIBUTION PARTNER)
832 S. Nova RD Unit 100,
Daytona Beach
Florida 32114, USA
and another online:
The Gunpla Hermits Shop
Online.
Postby Fuzznoggin » Wed Feb 17, 2021 3:18 am
Thanks for that info on the Boeing Grey. I'm ordering from them and the best part is they are just on the other side of the state. The 60ml's or so that I already mixed can be used for other projects. I'm going to go with the Boeing Grey!
Fuzznoggin
Postby Uros » Thu Feb 25, 2021 7:57 am
Looking good!
Postby Fuzznoggin » Sat Mar 06, 2021 10:29 am
Been a while but here is an update on the CargoLux 747-8F build. Finally, after all sorts of minor bug-a-boos, the first coat of Boeing Grey lacquer has been applied. Hopefully a few more passes tomorrow to complete the wings and fuselage, I can then airbrush the lead edge and begin installation of the leading edge flaps. Thought I might complete this by mid month but it looks more like the end of March. The base took some creativity and it has been scaled out to 1/144; including the markings. Photos taken today on temporary mount. Still need to install wing main gear yet. Wires will travel into the base for to power the aircraft lighting circuits.
More at a later date
Runway scaled out at 1/144:
ImageIMG_E9883 by Fuzznoggin, on Flickr
ImageIMG_E9884 by Fuzznoggin, on Flickr
Pitch angle is a bit high and will be lowered to between 2 - 7 degrees. Again, the mounts are temporarily installed
ImageIMG_E9885 by Fuzznoggin, on Flickr
ImageIMG_E9886 by Fuzznoggin, on Flickr
Fuzznoggin
Postby RayS » Sat Mar 06, 2021 6:57 pm
Nice progress, looking good!
If you use the BBCode link you will embed pictures in the post rather than links
ImageIMG_9872 by Fuzznoggin, on Flickr
Postby Fuzznoggin » Sun Mar 07, 2021 9:51 am
Finished airbrushing the Boeing Grey and buffed aluminum. Decided to do another light test so here she is. The stabilizer logo lights are still masked since I need to paint the center sections. Next video(s) should be better quality since I found the HD setting on the iPhone cam.
ImageIMG_9893-6 by Fuzznoggin, on Flickr
Fight Deck instrument panel
ImageIMG_9890 by Fuzznoggin, on Flickr
ImageIMG_9895-5 copy by Fuzznoggin, on Flickr
Fuzznoggin
Postby RayS » Sun Mar 07, 2021 4:16 pm
The lighting looks fabulous FN!
