Hawaiian Airlines A330-243
Postby RayS » Sat Jan 09, 2021 9:07 pm
This arvo I had a chance to start this one, I flew on one of these the Hawaii and back in 2018. So let's start with the parts. The Thai Airlines boxing of the Revell A330-300, Braz Models A330-200 replacement tail (x2), Braz Model Roll Royce RB211s for the A330 and the decals from 8a Decs.
What's in the box?
The kit Pratt and Whittney engines and the roller replacing them
The tails, from the left the kit tail, Braz Models A330-200 premod 48979, Braz Models A330-200 postmod 48979. The last one is the one fitted to the Hawaiian Airlines aircraft. It differs from the premod tail by having the same height as the A330-300 tail but has a wider chord and larger mounting bulges (the premod tail was taller and had the standard sized bulges and was fitted to early production A330-200s).
The fuselage sections I need to remove to make a -200 from a -300, 21 mm (6 windows) forward of the wing, 15 mm (4 windows) aft of the wing and the tail.
My method, line the cutting lines with dymo tape, scribe the fuselage where the cuts are to be made as a guide and then cut though with a razor saw, 4 cuts on each fuselage plus one for each vertical stab 10 cuts in all.
Cutting done in about 40 minutes...
And we have an A330-200 length fuselage
Next was to remove the resin poor stubs from the vertical stab and engines, I used a razor saw on the stab but that was taking too long on the first engine, so I sanded the stubs down on my 60 grit sanding board I use for vacforms, top engine done in this image.
First fuselage half being reassembled, I cut up a couple of the sections removed and glued them in the fuselage to reinforce the join, you can see the reinforcement parts at lower left and mid right.
Both sides done and taped together to make sure I got the cuts/length right on both sides (looks like I succeeded)
The engines were glued together with super glue, but I stuffed them both up (misaligned).
Some filling and sanding now required to fix the offset parts. When you don't want superglue to set instantly it does.
Re: Hawaiian Airlines A330-243
Postby hrtpaul » Sun Jan 10, 2021 11:13 am
Nice work and great colour scheme :)
Postby oz rb fan » Sun Jan 10, 2021 3:43 pm
that is going to look great.
Postby RayS » Thu Jan 14, 2021 8:21 am
Thanks guys.
Some gluing and filling action has happened, I started to get the flying surfaces assembled
The cabin windows were filled and cleaned up, I also added nose weight
and then the fuselage halves went together
Finally the engines were sanded, I not happy with one of them (bottom one) as the nosed section was hugely off centre and has a noticeable hump leading down to the intake lip after sanding, so I think some more putty required to make it less noticeable
Postby scotty100368 » Thu Jan 14, 2021 4:42 pm
The contouring suggests to me that you put the second engine nacelle front on upside-down... :?
Postby RayS » Fri Jan 15, 2021 7:32 am
It was just quick grabbing superglue and my lack of attention that had the nose ring set off centre, I sanded it down to get rid of the resulting lips. Some putty is restoring the shape a little.
I also had to knock down the base fin supports on the post mod fin as they looked to big, I think they still might be too big but better than before. Fin installed now, horizontal stabs just pushed in.
Next were the wings and adding the flaptrack fairings, winglets already added and puttied
And finally a mock up of the major parts, Left engine putty to have final shaping.
Postby F-27pax » Fri Jan 15, 2021 9:13 am
This is looking very promising and clean, I wish mine looked as good at this stage. I particularly like how the engines have turned out. I'm following your lead with this one because I have some A.330s and A.340s to make after I've finished my set of A.320s
Postby Fuzznoggin » Wed Feb 17, 2021 9:48 am
A lot of work, but the results will be fantastic! Looking forward to seeing more :)
Current Build - Aurora 737 refurbishing to JANET Airlines
Fuzznoggin
