Airfix Dc9
Airfix Dc9
Postby Graeme H » Tue Jun 26, 2018 8:23 am
OK, seeing as everyone is off building 737's I thought I would just do something different, so am going to do a pair of Airfix DC9's
ImageDSCN1309 by qfa_tsv, on Flickr
ImageDSCN1310 by qfa_tsv, on Flickr
they will be VH regs
Re: Airfix Dc9
Postby Graeme H » Thu Jun 28, 2018 1:43 pm
Small amount done, windows filled, doors all added, and wings together and trailing edges sanded down
ImageDSCN1312 by qfa_tsv, on Flickr
Re: Airfix Dc9
Postby F-27pax » Thu Jun 28, 2018 6:40 pm
Not much more to do, then.
Re: Airfix Dc9
Postby hrtpaul » Thu Jun 28, 2018 8:27 pm
Great work there mate :)
Re: Airfix Dc9
Postby RayS » Fri Jun 29, 2018 8:11 am
Are you going to add the missing fuselage crease that runs along the floor line Graeme?
Re: Airfix Dc9
Postby Ansett A330 » Fri Jun 29, 2018 11:51 am
RayS wrote:Are you going to add the missing fuselage crease that runs along the floor line Graeme?
I do believe he is going to. Be good if there was an appropriately shaped tool that could do it easily?
Re: Airfix Dc9
Postby RayS » Fri Jun 29, 2018 11:38 pm
Thanks Rob, I noticed Graeme's comment over on BM after I posted this. Runway 13 has a bunch of curved seam scraping tools that may be handy for scraping out the groove.
Re: Airfix Dc9
Postby Graeme H » Sat Jun 30, 2018 8:59 am
Yes, adding the lobe crease, and currently fixing the nose
I use superglue as it sets quicker and allows for the impatient modeller
ImageDSCN1313 by qfa_tsv, on Flickr
You can clearly tell I don't spend a lot of time setting up to take photographs ;) but if you squint a bit you can see the crease
I went and bought some of those RCI Clear Cockpits
https://www.ebay.com.au/itm/RCI-super-c ... 2749.l2648
designed for a different kit, but would probably fit, but I decided I would try my had at doing this myself, as I know what the nose of an DC9/MD80/MD90/MD95 looks like
Plan is to use Authentic Airliner decals for the windows and cockpit
Re: Airfix Dc9
Postby Graeme H » Wed Jul 04, 2018 5:28 pm
OK, moving right along I forgot to mention I have this a reference
ImageDSCN1325 by qfa_tsv, on Flickr
ImageDSCN1323 by qfa_tsv, on Flickr
Now Airfix went and did the engine pylon half on the engine and half on the fuselage, stupid
I find it best for me to take it off the engine, which is a whole lot easier than taking it off the fuselage
I use a scribing tool and sharp knife, takes no time at all
ImageDSCN1321 by qfa_tsv, on Flickr
Join the bits together, and attach to the fuselage, much easier to sand down
ImageDSCN1320 by qfa_tsv, on Flickr
Now on the fuselage there is a cabin pressure equilization vent on the port side, it's quite a large hole, with a round flap that closes it up by turning through 90 deg, I forgot to drill this out on the first one, and as it will need something to blank off behind it, it won't get one, need to make a round piece to go in the hole with a hinge in the middle of it
ImageDSCN1322 by qfa_tsv, on Flickr
You may be able to see the lobe crease on this photo, silver plastic doesn't show much
Re: Airfix Dc9
Postby RayS » Wed Jul 04, 2018 10:42 pm
I never thought of cutting the pylon part off the engine, stealing that trick for my next DC-9 build.
Some nice detailing there Graeme.
