Welsh Models 1/72 B737 BBJ (1)
Postby RayS » Wed Jan 25, 2017 8:01 am
This is a placeholder for one of my shelf of doom projects. It started life as a Welsh 1/72 Wedgetail but since I have a number of projects this year for a 34SQN Club display I am repurposing the build to a BBJ (the Wedgie will be building another time).
Updated pictures to be added tonight.
Re: Welsh Models 1/72 B737 BBJ (1)
Postby RayS » Wed Jan 25, 2017 5:06 pm
So here are some current work pictures
New APU housing fitted
You can see the layers of paint/primer sanded back :D But I will have to add some putty to fair it in.
More paint removed to add the Satcom antenna fairing
Fairing fitted. It is a bit squarish so I have knocked the edges down a little to round it off.
Vertical stab attatched
Some attention to the wing tips to removed them in prep for fitting winglets
And finally, engines are tacked on so I can figure out how much I need to extend the struts (have been told it is 6mm, so that is where I will start). Also added a friend to show size.
Postby VH-WAL » Wed Jan 25, 2017 5:23 pm
good work there ray, I am wrestling the Britannia while you do that
Postby Graeme H » Wed Jan 25, 2017 9:16 pm
Nice work there
Postby DesTROYer » Wed Jan 25, 2017 9:53 pm
Admirable.
Postby hrtpaul » Thu Jan 26, 2017 8:47 am
Way cool mate :)
Postby Ansett A330 » Thu Jan 26, 2017 10:27 am
Bloody
Brilliant
Job
Postby RayS » Sat Jan 28, 2017 3:04 pm
On with the build,
I spent the most of yesterday arvo extending the landing gear struts. I used some K&S brass tube and rod lengths.  I also modified the legs themselves as they don't seem to resemble the 737 gear leg much. Still need to create the retraction/extension arm as the Welsh kit also has you put it in the wrong place.
The legs are just pushed in for now and will need a little adjustment
Postby RayS » Mon Jan 30, 2017 8:19 am
Added the flap track fairings and one of the stabs and started some filling
You may have also noticed a little sanding back of the fuselage
Postby Adam the Akrodude » Mon Jan 30, 2017 11:51 am
VSH work there Ray! Coming along very nicely!
