Welsh Models U-4 (Gulfstream G-IV)
Re: Welsh Models U-4 (Gulfstream G-IV)
Postby RayS » Sat Apr 30, 2022 4:29 pm
Thanks Leigh
Some nose weight required it seems
I also added the winglets to the wingtips and am sorting out the filling and fairing in now
Looks like the clear parts in the cockpit are yet again not cooperating so I may be filling the windscreen and using supplied decals
Postby RayS » Thu May 05, 2022 9:17 am
It is coming together now, the cockpit windscreen was a pain and I could not get the clear parts sorted, so to stop stalling this one I resorted to Milliput to fill the openings ( I didn't know you could get black!)
The cockpit fittings were removed and dropped into the spares tub and openings filled
The nose gear leg was designed to be fitted to the bottom of the fuselage even though the instructions tell you to create a wheel well so the struts had to be lengthened, I did this will K&S brass tubing sections
I also added some detail before painting ( not that is will be seen)
The APU exhaust was also enhanced, the supplied detail as a small divot with a little nipple sticking out of it (engine not glued on at this stage)
Finally the main subassemblies we glued together and putty has been applied to the seems
With engines (again not glued yet)
Postby hrtpaul » Thu May 05, 2022 9:53 pm
Very cool mate :)
Postby RayS » Fri May 06, 2022 1:01 pm
CHeers Paul, first round of sanding done, more to go
Postby RayS » Wed May 11, 2022 6:22 pm
With so much on the bench I am jumping around between projects
Back on the G-IV again and it has been primed and sanded and primed and sanded, etc
And I have now turned my attention to the details, antennas, and the like as the fuselage is getting close to being painted
First attempt at attaching the tail GPS/Satcom? bulge to the vertical stab, it was sitting slightly too proud so it was removed and more material removed from the base, it will need some fairing in once the glue sets
Postby RayS » Sat May 14, 2022 9:59 am
G-IV vs G550 (MC-55A) comparison anyone?
And MC-55A with AP-3C(EW)
Postby RayS » Tue May 24, 2022 9:51 pm
With the seams sorted it is time to add the protruding parts before paint.
Landing gear
and antennas various...
Postby hrtpaul » Wed May 25, 2022 7:37 am
That's looking great Ray. Coming along very nicely :)
Postby RayS » Wed May 25, 2022 8:54 am
Cheers Paul, thanks for following along
Postby tor lives » Wed May 25, 2022 9:30 am
Wow!!!!!
That is amazing work Ray.
