QANTAS Avro 691 Lancastrian
Re: QANTAS Avro 691 Lancastrian
Postby Uros » Wed May 20, 2020 6:17 am
Nice work Ray. I realy like these war birds turned into civil machines.
Postby RayS » Mon Jun 15, 2020 9:39 pm
Thanks Uros, me too.
An L-188 Electra up next I hope, though it is sort of reversed, A civil machine that was turned into a war machine.
I regained my mojo with this one today after loosing interest in for a while
The engines when together with little fuss after replacing the the exhausts ( that is as far as I got, well I puttied the seams as well)
One of the props did give me grief as the holding pin slipped off the hub a little, enough to keep it in the nacelle but to much to keep a snug fit, there was a 2 mm gap between the front of the nacelle and the back of the hub, so it was basically rattling around rather than spinning. Anyway the prop ended up falling off the pin so I split the nacelle open and reassembled it properly.
Engines were sanded and added to the wings, the joins then filled and sanded again, right wing
And the left wing with the troublesome No 3 engine gluing prior to puttying the nacelle to wing gaps
Next I started to add the horizontal stabs and test fit the canopy, I found that there was a gap at the front which needed some shimming
and finally the other stab fitted and glue setting
Let's see if I can now see this to the finish!
Postby hrtpaul » Tue Jun 16, 2020 12:36 pm
Looking good so far man :)
Postby RayS » Mon Jun 22, 2020 3:02 pm
Thanks Paul,
I have the main assemblies together now, it has been primed and I'm still sanding some of the rough spots
Gear legs going on
and the main gear doors, must be time to prime again.
...and primed
Postby Graeme H » Mon Jun 22, 2020 5:49 pm
Coming along nicely
Postby RayS » Tue Jun 23, 2020 5:52 pm
Thanks Graeme, it has change colour a couple of times now
To black...
and aluminium
Postby RayS » Sun Jun 28, 2020 1:15 pm
Now approaching the finish line with this one, I have painted the internals, not sure of the colours so made it up with interior green featuring a lot. The wheels are also painted and on
I also added the deicing boots that need a tidy up
And it was finally time to add the canopy assembly, I tried to adjust as much as I could before fitting but some filling still required (and some persuasion to help the glue set).
It has since been filled, I letting it all set before some sanding and further paint work
Postby Graeme H » Sun Jun 28, 2020 1:43 pm
Good to see it getting there, didn't realise that there was so much resin, wings and engines in particular, is there a lot of difference to the Lanc ones?
Late Edit
Silly me, when looking over the post I see that is the strange colour that the US Airfix kit is moulded in
Postby RayS » Sun Jun 28, 2020 4:39 pm
All good Graeme,
some more painting done, I just have to re-mask one of the deicing books on the vertical stabs as I botched it a tad
Postby RayS » Mon Jun 29, 2020 10:06 pm
Calling done finally
And with a friend
