Airfix Dc9
Re: Airfix Dc9
Postby hrtpaul » Thu Jul 05, 2018 7:40 pm
Great work Graeme :)
Re: Airfix Dc9
Postby Ansett A330 » Fri Jul 06, 2018 2:00 pm
Graeme H wrote:OK, seeing as everyone is off building 737's I thought I would just do something different, so am going to do a pair of Airfix DC9's
https://www.youtube.com/watch?v=xRvCwtLLV6I
Re: Airfix Dc9
Postby tor lives » Wed Jul 11, 2018 5:15 am
Ummmm do you actually build any models, or just follow Graeme around ???
Re: Airfix Dc9
Postby Graeme H » Wed Jul 11, 2018 3:41 pm
OK, got the wings and all the attachments on
ImageDSCN1326 by qfa_tsv, on Flickr
The silver plastic and superglue as a filler make it look as though the seam hasn't been done, but it has, I use superglue because the metallic finishes think it's the same as plastic, unlike other fillers
Now sitting on it U/C legs waiting to be taken into the paint shop
ImageDSCN1327 by qfa_tsv, on Flickr
I won't put the stabs and engines on until after I decal it, makes it so much easier
Re: Airfix Dc9
Postby Graeme H » Thu Jul 12, 2018 2:13 pm
OK, making the nose look a little more McDD like
ImageDSCN1332 by qfa_tsv, on Flickr
still have fair bit of precision sanding to do
Re: Airfix Dc9
Postby RayS » Thu Jul 12, 2018 2:44 pm
Looks good, I dragged a Minicraft DC-8 off the shelf of doom on the weekend and found it already had the flat area in front of the windscreen already present.
I will have to check my MD08 build to see if it is the same.
Re: Airfix Dc9
Postby Graeme H » Thu Jul 12, 2018 4:57 pm
Yes the Minicraft MD80 does have it, as does the Fly DC9, but it is better on the Eastern Express DC9
Re: Airfix Dc9
Postby Graeme H » Thu Aug 02, 2018 1:48 pm
I am struggling with modelling at the moment, as I have a very bad dry cough that when it starts i'm unable to do anything much, doctor has put me on Seretide which helps a little, but I'm very asthmatic and unable to breath properly, get exhausted easily, none of this is good
So managed to put some of that black Ultimate Primer on, does anyone have any experience with Alclad over this stuff or should I also use Alclad primer?
ImageDSCN1338 by qfa_tsv, on Flickr
Re: Airfix Dc9
Postby hrtpaul » Thu Aug 02, 2018 8:03 pm
If you want a nice smooth finish then you'll want a gloss surface. You could always sand the primer with very fine micromesh but you'll want to be sure EVERYTHING has been sanded smooth or it'll stick out like dogs knackers. Personally I'd be giving it a coat of gloss black to be sure :)
Re: Airfix Dc9
Postby Graeme H » Sat Aug 04, 2018 10:54 am
This is my first attempt at using that Ultimate primer, odd stuff to use to say the least, the plan is to put Alclad Black gloss primer on next
I'm also using this to highlight the flaws that need fixing and to provide that bit of depth to correct some of those flaws, in the end I would have been better off using the Tamiya spray can grey primer I think.
You can get this stuff in white and grey as well as black, but not really a fan of it
