Microscale Decal Film
Postby hrtpaul » Tue Mar 03, 2015 12:38 pm
Ok peeps. I'm up to the decalling stage with my Hasegawa 1/48 Ki-27 Nate. I put one of the decals in the water and it shattered :o :( I've never had this happen before but have heard about it. I have a small bottle of this decal film stuff but not sure how to apply it. Can it be sprayed though an airbrush and if so, I assume using low pressure. Also how many coats would you lot recommend? Cheers :)
Re: Microscale Decal Film
Postby Nicolas_Fantich » Tue Mar 03, 2015 6:51 pm
Paul,
Microscale's liquid Decal Film is a godsend in a bottle.
I guess that the Hasegawa decals you are using are probably quite old. I've never had Hasegawa decals perform the 'shattering' trick on me, only older Roodecals (rather catastrophically).
Don't bother clogging up your airbrush. Get a flat broad brush, load it up generously with the liquid and use broad single but overlapping strokes over the entire decal sheet or only over those images you require for decalling the model. Allow to dry. I think this liquid has a solvent of sorts as it evaporates reasonably quickly. Don't be too worried if it looks like you've put down quite a lot; when dry it remains as a thin film. DO NOT repeatedly brush over the same location. This is not fence painting (which I am doing at the moment actually). A second coat might be useful if you are a 'worry wart', however, it will make the resulting decal thicker, which may not be what you want/need depending upon what your requirements/constraints are. Practice with a spare decal to get some confidence.
This is great for sealing over inkjet printed images or photocopied images/text on decal paper. Again, only SINGLE strokes with slight overlapping. Failure to adhere to these guidelines will result in a higher than otherwise probability that you will make the printed/drawing image run/smear. No running back to Uncle Nic to complain that what he said was crap, ok ?
Years ago I used this stuff to create decals. I did an ink drawing of a caricature and some text legends and over coated with this product once the ink had dried. I was able to successfully apply the decals in the usual way. A winner !
Oh, I washed out my brushes with an alcohol-type solvent after brushing this stuff. I expect a Windex type product would be acceptable also. Maybe a lacquer thinner also ? The proof to me was that the brush was clean and supple and able to be used again.
Good luck m8 ;)
Nicolas
On the Bench
1/144 Academy Douglas DC-6B - Adria Airways YU-AFF
1/48 Revell North American P-51D Mustang 'Miss America'
1/72 Airfix North American P-51D (Cavalier) Mustang N51RH
1/72 Airfix North American P-51D Mustang N64CL 'Miss Van Nuys'
Nicolas_Fantich
Postby hrtpaul » Tue Mar 03, 2015 7:00 pm
Ta Uncle Nic. I'll give it a go over the next couple of days. Cheers :)
Postby Nicolas_Fantich » Fri Mar 06, 2015 7:57 pm
hrtpaul wrote:.....Ta Uncle Nic.........
Just watch yourself young scallywag ;)
Hopefully you get some wins with the decals.
Nicolas
On the Bench
Nicolas_Fantich
Postby hrtpaul » Fri Mar 06, 2015 8:34 pm
I'm experimenting at the moment but it's looking promising :D
