A/CAM Group Build: Suggestions from you.
Postby tor lives » Fri Nov 26, 2021 10:10 pm
OK, so after much consideration, I have decided to give an A/CAM Group Build another crack.
I now need your input as to what the subject of the "new" Group Build will be.
The options are:
- HS-125, (any scale, any variant, any manufacturer).
- Airfix 1:144 737-200, (perhaps we finish what we started here).
- Movie Stars, (any aircraft that has stared or even cameoed in a movie or TV).
- Emergency Services Aircraft, (to tie in with our A/CAM Model Expo display for next year).
Once a subject has been decided on, I will set-up a specific Group Build Forum that will lay out the parameters of the Group Build.
Over to you lot, (I will run this for a few weeks so everyone can have their input)......and no, the above subjects are NOT negotiable :D
Re: A/CAM Group Build: Suggestions from you.
Postby BradG » Fri Nov 26, 2021 10:50 pm
Should be for next years model expo theme, so emergency aircraft.
Postby F-27pax » Sat Nov 27, 2021 5:49 am
Emergency service aircraft!
Postby RayS » Sat Nov 27, 2021 12:19 pm
Happy for Emergency Air as well, have a part started Security Civile C-130A to finish, if I can find it!
Postby hrtpaul » Sat Nov 27, 2021 7:56 pm
I'll try to contribute to whatever the group decides :)
Postby Uros » Sun Nov 28, 2021 7:06 am
Emergency aircraft. I have a few in the stash, that would fit.
Postby BradG » Wed Dec 01, 2021 6:14 pm
Weeeeoooo weeeeooo weeeeoooo...sorry, just practising for model expo.
