1/48 J-3 Cub
1/48 J-3 Cub
Postby Cap'n Wannabe » Tue Jun 18, 2019 12:13 pm
Hi All..
I picked up the Hobbycraft 1/48 J-3 Cub at the swap'n'smell, and have decided to build it to try to get my mojo back. Also, I've just finished setting up my modelling space in the garage, and I'm itching to try it out..
Anyhow, there is a noticeable lack of detail in the cockpit, and even though I swore this build would be strictly OOB, I can't help myself.
Cockpit photos show there isn't much required, and most of it is fairly simple to do. There is one area, however, that is a challenge - the fuel shut-off lever. It sits in a recessed area on the LH side of the cockpit.
My question is: how can I make a small recess the right shape for it? See pics..
The kit parts....
What I'm trying to achieve..
Re: 1/48 J-3 Cub
Postby Tony P » Tue Jun 18, 2019 10:48 pm
Dremel it. Just a little bit. I want to see you Dremel it, just a little bit, as it grooovveess.
Re: 1/48 J-3 Cub
Postby Uros » Tue Jun 18, 2019 11:52 pm
You can make a new sidewall out of thin styrene with a hole in the right place. Or drill a hole, sand it to shape and glue a piece of thin styrene same shape flush with outer surface. Or just make a rim out of wire ang glue it to the wall. I don't think it will be noticable that there is no recess. I hope this makes sense.
Re: 1/48 J-3 Cub
Postby hrtpaul » Fri Jun 21, 2019 9:56 am
I agree with Uros. I don't reckon you'll be able to notice if it's recessed or not :)
Re: 1/48 J-3 Cub
Postby Cap'n Wannabe » Fri Jun 21, 2019 10:35 am
After a lot of thinking, and some tinkering around, I think I'll simply (until I actually start doing it) make a flange and glue it in the right spot. It's only about 2mm x 3mm anyhow..
Re: 1/48 J-3 Cub
Postby hrtpaul » Fri Jun 21, 2019 11:31 am
Thinking? I bet that hurt :lol: :lol: :lol:
Re: 1/48 J-3 Cub
Postby Adam the Akrodude » Sat Jun 22, 2019 3:22 pm
'd slightly recess it or just paint it - it's only 1/48 in any case. Still, a piece of plastic card is so easy fitted. Looks a fun build.
Users browsing this forum: No registered users and 29 guests
