Braz 1/144 Tu-114 conversions
Postby DDGboy » Thu Dec 13, 2018 7:31 pm
Intended for the Trumpeter Bear H or J kits, does anyone know if they will work with the Revell Bear D?
TIA, Jamie
DDGboy
Re: Braz 1/144 Tu-114 conversions
Postby Ansett A330 » Thu Dec 13, 2018 8:46 pm
Someone asked a similar Question on another website way back on veinticinco de noviembre 2007 ...
and never got an answer.
Postby DDGboy » Fri Dec 14, 2018 4:40 am
Hahaha, thanks mate, sounds promising! ;)
DDGboy
Postby Ansett A330 » Fri Dec 14, 2018 5:20 am
I suppose the other alternative is to see if there is a comparative Review of the Kits anywhere that might give you a hint as to their interoperability with respect to the BraZ conversion?
Postby Ansett A330 » Fri Dec 14, 2018 5:27 am
Trumpeter Parts layout :
and Reviews :
https://www.cybermodeler.com/hobby/kits ... 3904.shtml
https://www.cybermodeler.com/hobby/kits ... 3905.shtml
How does that compare with the Revell Kit?
Postby Graeme H » Sat Dec 15, 2018 7:13 am
The alternative is to email Ivo at Braz and ask him if he knows of anyone who may have done it
Postby DDGboy » Tue Dec 18, 2018 7:42 am
Thanks guys, a bit of digging shows that it may well be doable, as the Braz resin fuselage has cutouts on the underside matched (sort of!) to the Trumpeter wing joins -
https://i.ebayimg.com/images/g/8JgAAOSw ... -l1600.jpg
The Revell Bear kit has the fuselage split top and bottom, not horizontally, and the lower wing is continuous across the join, meaning the centre section can be cut to match the resin, and the upper wings have standard tabs which can simply be trimmed to match-
https://www.scalemodellingnow.com/hnair ... -tu95-bear
A similar approach pre-Trumpeter kits. The conversion includes a (strengthened) nose gear leg and the extended flaps - http://www.hyperscale.com/galleries/2002/tu114jt_1.htm
I've bit the bullet and purchased the conversion, but at my building rate it'll be finally completed by one of my distant relatives in their settlement on Mars!
DDGboy
Postby VH-WAL » Tue Dec 18, 2018 10:03 am
[Quote/]
I've bit the bullet and purchased the conversion, but at my building rate it'll be finally completed by one of my distant relatives in their settlement on Mars![/quote]
Ah well look on the bright side..if it's going to take that long whether it fits or not just doesn't matter :lol:
Postby Ansett A330 » Tue Dec 18, 2018 6:03 pm
DDGboy wrote:Thanks guys, a bit of digging shows that it may well be doable, ...
... it'll be finally completed by one of my distant relatives in their settlement on Mars!
Tell them that (that it's doable) but don't leave them any hints as if it turns out it's not doable when they strike trouble with it they'll believe you were Earth's greatest Modeller because they believe that you could do it.
Postby TheChronicOne » Wed Dec 19, 2018 6:02 am
Hmmm.... I am curious as well. I picked one of those Bears up recently. I'll either do a completely fictional "what if" plane with it and turn it into an airliner with whatever stuff I have on hand... OR... go all-in and convert it to a proper Tu-114. It all depends, of course...
Users browsing this forum: No registered users and 3 guests
