America West decals by 26
Postby jayveedee » Sat Feb 10, 2018 10:52 am
I flew to Vegas in 2002 on a honeymoon flight aboard an American West A319.
I've always wanted to model that plane but the only proper decals are by 26 and
are for the A320. Can they be cut down to fit the 319? Also is Revell the only game
in town for a 1/144 A319? Thanks---John
jayveedee
Re: America West decals by 26
Postby Graeme H » Sat Feb 10, 2018 4:05 pm
The Revell is the only one without resorting to cutting down the Zvezda, and although Revell got it re engineered from the A320/321, the designer stuffed up big time and still added the little flap track fairings for the double slotted flaps only fitted to the A321 and there is not much commonality between it and the A320/321 kit
So a bit of cutting those extra flap track fairings off, then filling the extra flap bit and sanding it all smooth, just adding to your modelling pleasure. :D
I can't see why you wouldn't be able to cut down the decals, they seem to be all separate rather than having the windows and name logos all in one, and the emergency exit on an A319 is over that logo on both sides, and it is printed separately as well, seems Ray may have had that in mind when you look at how the decal is done, not sure about regos though, he has done them as N6, and the A319's are N8, but he has done a string of numbers to make up your own, so unless you need a rego with a lot of 8's you should be good.
With the A319 kit, I think they have always had both engine types included.
Postby jayveedee » Sun Feb 11, 2018 12:57 am
Thanks, I'll just have to get dimensions to figure size difference between A319 and
A320 and study some pics to figure where the decals should be cut. Thanks again---John
jayveedee
Postby jayveedee » Sun Feb 11, 2018 9:44 am
Almost forgot I have TwoSix retro decals for U. S. Airways- America West. I
may be able to use these and the America West logo off the TwoSix A320
for the 319. The retro decals are sized for the 319 and have serials in 800s.---John
jayveedee
Postby jayveedee » Sun Feb 11, 2018 9:48 am
TwoSix A320 decals.---John
jayveedee
Postby Graeme H » Sun Feb 11, 2018 12:16 pm
Yes can see that would be easier
