White over red
White over red
Postby hrtpaul » Thu Jul 28, 2016 1:34 pm
Hey guys. Is it possible to paint white over red and have it opaque enough so it doesn't look pink? Cheers :) :) :) :)
Re: White over red
Postby Cap'n Wannabe » Thu Jul 28, 2016 2:36 pm
Yep....takes a good few coats though..
Re: White over red
Postby tor lives » Thu Jul 28, 2016 2:41 pm
It can be done depending on the paint you use and the number of layers you apply (and you will need a few coats regardless of the paint-type). The risk of getting a nice rich, uncompromised, white finish over red though is the paint edge "lip" may build up to noticeable proportions depending on how many coats you apply.
Desirably though, red over white if possible.
Re: White over red
Postby RayS » Thu Jul 28, 2016 3:09 pm
If you really have to I would go a light grey and then a few coats of white. It reduces the number of layers of white you need to add.
Re: White over red
Postby VH-WAL » Thu Jul 28, 2016 5:12 pm
like Ray said but matt white or tamiya white pimer first followed by gloss white or clear topcoat to get the gloss back
Re: White over red
Postby tor lives » Thu Jul 28, 2016 8:45 pm
What are you painting ???
Re: White over red
Postby hrtpaul » Fri Jul 29, 2016 7:12 am
Thanks guys. I've got to get white circles for the numbers on my racing Macchi. I've found some white circle decals that I might try before paint. The paint edge was what I'm trying to avoid as unfortunately I painted the whole thing red before I thought about the circles for the numbers. Ya get that :oops: :oops: :oops: :oops: :oops:
Re: White over red
Postby BradG » Sat Jul 30, 2016 5:28 pm
White decal paper and a compass cutter, instant white circles. To avoid the lip, don't let the paint hit the surface very wet, otherwise the air blows it towards the edge and you get the pronounced lip. Keep the mixture a little on the thick side and use matt. Also, if you're using a solvent based matt white and still end up with a small lip, a good hot gloss coat does a nice job of burning off the thin edge. Also paint it over a matt surface, it will stick once it hits.
Users browsing this forum: No registered users and 19 guests
