Revell 727-100
Revell 727-100
Postby kfutter » Mon Jan 04, 2016 4:17 pm
With the news that Revell will be re-releasing its old 727-100 kit this year, I decided to pull mine out (the kit, I mean...) and take a look at it. I bought this kit from our fearless leader a few years back, but it's remained firmly entrenched in the stash ever since. Last night, while watching a movie, I found myself sanding all the rivets off the fuselage, and thinking about what I could do with it - scratch-built wheel bays being the first thing that came to mind. So, before I get ahead of myself, does anybody have, or can direct me to, some decent references for these areas on a 727? Might even build it in conjunction with the Airfix kit I have, and go the two-for-one deal.
Thanks in advance!
Re: Revell 727-100
Postby tor lives » Mon Jan 04, 2016 8:23 pm
Not "close up" ideal Kev....but a start perhaps:
I will have a look for what else I may have.
Re: Revell 727-100
Postby RayS » Mon Jan 04, 2016 10:28 pm
Check out this video, from the 1 minute mark there are some shots in the main wheel wells.
If you google 'B727 Walk'around you will find some other videos as well.
...and I found a comprehensive walkaround over on BritModeller by our own Graeme H. with some wheel well shots.
Re: Revell 727-100
Postby kfutter » Mon Jan 04, 2016 10:44 pm
Rays - thanks kindly, gents! So the inner gear doors were closed except for extension and retraction, yeah? That will simplify things enormously. On the other hand, so would building it wheels-up...
Re: Revell 727-100
Postby tor lives » Tue Jan 05, 2016 8:25 pm
G'day Kev,
Yep......those inner doors remain closed except for extension/retraction of the main gear. Same as the 707, 757, 767 etc
Re: Revell 727-100
Postby scotty100368 » Wed Jan 06, 2016 3:35 pm
Guys, check this out...
A 747 undergoing landing gear testing (all 4 together from 1:28)
https://www.youtube.com/watch?v=ChPLaXqO0eQ
You can clearly see the inner doors close back up after the legs lock down!
Scott. :)
Re: Revell 727-100
Postby hrtpaul » Wed Jan 06, 2016 10:18 pm
@1:28 it's only the forward 2 bogies that are extending. I doubt they could do all 4 (retract or extend) at the same time due to the sheer pump volume output that would be required from the hydraulic rig. Interesting to see they're doing retracts outside on such a big plane as well :)
Re: Revell 727-100
Postby kfutter » Thu Jan 07, 2016 6:42 am
Thanks for your input, fellas. Given how little can really be seen, I'm wondering now whether it's worth the bother. Perhaps even a wheels-up display might be best. Hmm...
Re: Revell 727-100
Postby RayS » Thu Jan 07, 2016 7:58 am
hrtpaul wrote:@1:28 it's only the forward 2 bogies that are extending. I doubt they could do all 4 (retract or extend) at the same time due to the sheer pump volume output that would be required from the hydraulic rig. Interesting to see they're doing retracts outside on such a big plane as well :)
There is mention in the blurb under the video that states the Hydraulic cart used does not have the grunt to do all 4 bogies at the same time.
'Testing the retraction after changing all landing gears. Testing one or two at time, because the ground pneumatic* doesn't supplies enough power to move all gears together (the ADP's are hard at work).' *I expect he means 'hydraulic'
Re: Revell 727-100
Postby hrtpaul » Thu Jan 07, 2016 5:14 pm
I'm not that smart to read more than I have too ;) ;) ;) ;) ;) ;)
