Nuernberg 2019
A place for sponsors and other manufacturers to advise A/CAMers of the "good stuff" to come
Nuernberg 2019
Postby RayS » Thu Jan 31, 2019 8:21 am
Link to IPMS Germany images
I see Revell are reissuing their B767-300 in Rolling Stones livery.
Also noted ( as mentioned before)
B747-100 reissue
A320 and A321 NEO
A350, A380 and EMB190 in new Lufthansa decals
A380 in Emirates 'Wild Life' scheme
A380 with light and sound kit
Antonov AN225
Re: Nuernberg 2019
Postby Ansett A330 » Thu Jan 31, 2019 2:38 pm
RayS wrote:I see Revell are reissuing their B737-300 in Rolling Stones livery.
I know I need Glasses but pretty sure that's a 767-300 ...
Now the big question would be : "Theirs" or Zvezda's?
Re: Nuernberg 2019
Postby RayS » Thu Jan 31, 2019 8:26 pm
Damn fat fingers!!!!! I knew what I meant! :D
Re: Nuernberg 2019
Postby hrtpaul » Sat Feb 09, 2019 2:51 pm
Is the 747-100 any good?
Re: Nuernberg 2019
Postby tor lives » Sat Feb 09, 2019 4:19 pm
hrtpaul wrote:Is the 747-100 any good?
The Revell 1:144 Boeing 747 Classic is the best main-stream release in its scale.....much better than the Airfix interpretation of the same aircraft, and pisses all over that abomination from Nitto :? , (yet, in 1:100 scale, the Nitto 747-100 is simply superb.....go figure).
Re: Nuernberg 2019
Postby F-27pax » Sat Feb 09, 2019 11:20 pm
I used a lot of earlier pressing of the 747-100 when I was making 747s a few years back. While not as good at the Revell 747-400 they were pretty good for 1/144 and I'd by happy to buy some more if I needed them.
Re: Nuernberg 2019
Postby hrtpaul » Sun Feb 10, 2019 10:03 am
Cheers man. Guess I'd better acquire a couple. Always loved the old school QF scheme. How hard is it to convert a 100 to an QF SP?
Re: Nuernberg 2019
Postby RayS » Sun Feb 10, 2019 10:56 am
A lot of work to make an SP Paul, There is an old FSM article floating around that details it. Fuselage needs shortening, rear fuselage reshaped and vertical stab increased in length and chord.
And then you need aftermarket rollers to replace the kit engines.
There's also a build thread on ARC where an SP conversion is/was being attempted.
Re: Nuernberg 2019
Postby tor lives » Sun Feb 10, 2019 5:39 pm
Paul, there are several options available to you if ya want to get yourself a 1:144 747 SP.
As mentioned by Ray, in the March 1994 edition of Fine Scale Modeller magazine, a comprehensive article on converting a 1:144 Revell 747-100/200 into a Boeing 747 was published. I have you covered on this, (indeed I have already printed you a copy), but here is the article for your to ponder:
Your 2nd option is to try and track down the old, (and long OOP), Sasquatch 747 SP resin conversion fuselage for the Airfix 1:144 747-100/200.
The reason the Airfix kit is good for this conversion is that you can use the wings virtually unmodified from the box, as the prominent trailing edge flap canoe fairings, (which are NOT a feature of the SP), are not cast into/onto the wing. If you really want to get technical though, you will need to bog and re-scribe the trailing edge flap arrangement, as the flap design on the SP was different, (and much simpler....basically a scaled-up 707 flap arrangement), to that of the "standard" 747.
Your will also need to get yourself a ship-set of short-body RR RB211s.
Your other option is to simply order a 1:144 Qantas 747 SP from Welsh Models.
Hope that helps
Re: Nuernberg 2019
Postby hrtpaul » Mon Feb 11, 2019 10:14 am
Hmmmm being a lazy prick I think the SP won't be getting done anytime soon. Thanks for all the info though guys. I may have to get a copy of that article off you though Ray :)
Return to Product Announcements
