1/72 Hasegawa Ki-44 II Tojo
Postby _BlackHawk_ » Wed May 28, 2014 4:31 pm
Not a bad little kit, although the decals were pretty thick and detail is sparse. I masked and painted the fuselage red and white along with the anti glare panel and the wing leading edge. I really should have painted on the roundels too. This aircraft was armed with two 40mm HO-301 cannon designed to knock down B-29's, but in reality, the weapon was just as lethal to the pilot as the B-29 due to the low muzzle velocity. Pilots had to get dangerously close to open fire with any accuracy.
Re: 1/72 Hasegawa Ki-44 II Tojo
Postby hrtpaul » Wed May 28, 2014 4:38 pm
That looks cool as mate. Great job :)
Postby tor lives » Wed May 28, 2014 5:10 pm
I'll give you your due Ace....you sure do build a dam fine model. 40mm cannons :shock: ...that's pretty kick-arse!!!
So were they successful in bringing down B-29s????
Postby _BlackHawk_ » Wed May 28, 2014 5:53 pm
Not really. Most were destroyed on the ground in the Philippines and by that time the Japanese were halting production of the Tojo for the Ki-84 Frank. The weapon had a 10 round box magazine with a 450rpm firing rate but the case less ammunition meant you'd have to close to within 150 meters of your target....I'd rather be blasting away with 20mm out of range of return fire!
Postby oz rb fan » Wed May 28, 2014 9:41 pm
nice job brad...i have the new sword kit....but it may have a problem...and i might just have done too many japanese planes this year :o
Postby Adam the Akrodude » Thu May 29, 2014 10:58 am
Great work Brad - nice job on the wash there. Kinda odd looking bird isn't it. I bet it would look amazing as a racer!
