1/48 Spitfire PR Mk.1A
Postby hrtpaul » Fri Jun 28, 2019 2:23 am
I HAVE FINALLY TOUCHED A MODEL FOR THE FIRDT TIME IN 3 MONTHS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I was worried I'd forgotten how to build. I have a few things I wanna build but with 12 on the go, I need to finish something. I started this a while ago when I developed an interest in PR Spitfires, mainly due to the uniqueness and pretty colours. This is a conversion of the now older tool 1/48 Tamiya Mk1 kit using a Pavla conversion. The main conversion tasks are removing the guns and panel lines, drilling camera ports in the wings and a PR canopy. It appears Pavla have the incorrect roundels for this particular aircraft in the conversion but more research on this is needed. This aircraft was the first Spitfire to carry out a recon mission way back in '39 and will be painted in Camotint aka Sky. Hopefully I'll have the wings and tail on by the end of next week before heading back to POM for another 3 week tour.Anyway here's where it's at so far :)
Lots of sanding :roll:
Re: 1/48 SPitfire PR Mk.1A
Postby Ansett A330 » Fri Jun 28, 2019 3:05 am
2:23 am
Night Shift eh?
Postby hrtpaul » Fri Jun 28, 2019 10:10 am
Nah couldn’t sleep :(
Re: 1/48 Spitfire PR Mk.1A
Postby Adam the Akrodude » Mon Jul 01, 2019 2:32 pm
Great to see you're back on the modelling tools Paul! Great work so far.
Postby Graeme H » Tue Jul 02, 2019 9:42 am
yep great to see you back at the bench
Postby hrtpaul » Sun Jul 07, 2019 6:50 pm
Got a few hours in the model room today and it's the last time before I head to POM again for 3 weeks.
Got the belts on the seat
The cockpit all together
And the cockpit in the fuse
Postby Migrant » Sun Jul 07, 2019 10:25 pm
Looks good! What's the purpose of the wires attached to the seat harness?
Mike G
____
Calgary, AB, Canada
Migrant
Postby hrtpaul » Mon Jul 08, 2019 12:14 am
Migrant wrote:Looks good! What's the purpose of the wires attached to the seat harness?
Thanks mate. The wire is to simulate the cable that connects the shoulder harness to the airframe :)
Postby Migrant » Mon Jul 08, 2019 12:42 am
Thanks for the info; good to know for future Spit builds.
Mike G
____
Calgary, AB, Canada
Migrant
Postby hrtpaul » Thu May 21, 2020 2:57 pm
Been plodding along with this thing for a while now. Sanding those wings was a PITA but ya get that. I also drilled the holes for the cameras in the wings and used Little Lens to simulate them. They'll be painted with some different clear colours after all the airframe painting has been completed. I also had to scratch up an air vent under each wing which wasn't that difficult. The wings and stabs were then fitted to the fuse and gaps filled. A bit more dicking around is required and then it'll be primer and paint time.
