PAC CT-4A Airtrainer.
Postby RayS » Thu Apr 11, 2019 9:28 pm
I thought I might drop this here since it will be in RAAF markings.
I started the Kiwi resin kit a couple of weeks ago as part of a BritModeller Trainers Group build.
Work has progressed quickly but I am losing interest as my AModel G-550 and C-37B have arrived (must resist the temptation!)
I have a connection to the build subject A19-49 as it was the first CT-4 I jumped into at 1FTS as part of a misguided notion to become a RAAF Navigator last century.
The kit is all resin with a vac form canopy
I started by removing the pore stubs from the pieces with the trusty razor saw
Such a small little piece of resin compared to the C-17 I am working on, that's the horizontal stab for size reference
I started with pinning the main parts for some joint strength
Studying some diagrams and images I found the rear fuselage need putty!
Since I was putting it on its wheels I had to make sure it was not going to be a tail sitter, so I drilled out the nose piece and the forward section of the main fuselage piece
and filled it with lead
But that was not enough, so I cut the rear fuselage in half and drilled those parts out as well
and then stuck it all back together
Next was the gear, The resin looked flimsy so I recreated the main legs with styrene and brass wire
resulting in this
That is as far Ias I got, next will be the canpoy and starting to figure out haow the cockpit parts go in.
Re: PAC CT-4A Airtrainer.
Postby BradG » Fri Apr 12, 2019 3:46 pm
Looks like a neat kit.
Postby hrtpaul » Fri Apr 12, 2019 4:32 pm
That looks really cool Ray :)
Postby RayS » Sun Apr 14, 2019 2:56 pm
Did I tell anyone I don't get along with vacform canopies?
Well now you know, I managed to take too much off when removing the excess, I will be able to recover the over removal. The other issue is that it is not a straight slot in affair. I need to rework the area under the windscreen to make it look like it is supposed to be there.
I made up a new instrument panel that is closer to what is in the actual aircraft.  I hope it will look OK under a lick of paint.
The seats have also been replaced as the supplied ones were a little undersized.
Postby F-27pax » Sun Apr 14, 2019 9:12 pm
This looks a lot more friendly than rge ancient Tasman Models kit I made a couple of years ago. Yours is looking very good so far.
Postby RayS » Sun May 12, 2019 9:26 pm
Thanks Leigh and some progress!
Internals fettled and painted, added some tape belts. The interior is a tad boring being grey and black.
Canopy has been fitted, there was a huge gap under the forward edge
which I filled with some painted rod, this will be puttied over once the future on the canopy is set and I have masked it.
I also need to tidy the join around the other seams and fair them in with some putty
Postby F-27pax » Mon May 13, 2019 7:51 am
This kit looks like a vast improvement on the Tasman Models kit I made a couple of years ago. Was your kit around at the time? If it was, I should have thrown mine in the bin and made this one, it looks lovely and a lot more accurate too.
Postby RayS » Wed May 15, 2019 6:07 pm
I understand this one came from the Tasman kit. The bloke who ran Tasman started Kiwi resin up.
This one is a bit more refined
Users browsing this forum: No registered users and 19 guests
