Atlas, not the book or the Greek Titan
Re: Atlas, not the book or the Greek Titan
Postby RayS » Sun Oct 21, 2018 10:27 am
It is finally starting to take shape
Some nose weight going in, Revell suggested 80gs I added 90
Sponsons going together
Engines and props in final stages, the fit of the nacelles again was not the best, some putty and clean up required.
And the fuselage which needed a lot of help. I am not sure if my wiring contributed to it.
Some experimenting with a payload :)
And a size comparison with the C-17 I am being distracted from
Postby RayS » Mon Oct 29, 2018 8:43 pm
Major subassemblies have now gone together now
With some more gaps to contend with
I also added an APU exhaust pipe which is quite prominent on the upper fuselage, still to reshaped and tidied up
Postby RayS » Mon Oct 29, 2018 9:04 pm
I started to mask so some priming could be done. I am using the Eduard mask set which is great (to a point)
Something not quite right and then I figured it out, only 2 masks for the nose wheels and an extra pair for the mains, 13 main wheels? Most of the wheels are on 2 sprues, the 2 outboard nose wheel parts are on a 3rd sprue, so I expect they were missed by the Eduard folk. I had to reuse the 2 nose wheel masks to do the outboard sides
Gear legs assembled and wheels painted black, though they now need redoing after they were assembled and seams removed.
More seam work
Props painted
and the power plants ready to fit
Some primer on and some more putty to follow. Will it end?
Postby Ansett A330 » Mon Oct 29, 2018 9:25 pm
Fantastic work Ray.
Are you trying to get it finished for the ACT Show next Month?
Postby RayS » Tue Oct 30, 2018 7:41 am
Thanks Rob,
Yes, it is for an RAF 100 club display table.
Postby Adam the Akrodude » Tue Oct 30, 2018 4:26 pm
Very nice indeed Ray. That's a lot of bogging you've had to do.
Postby Graeme H » Sat Nov 03, 2018 4:12 pm
RayS wrote:I saw that Rob, which got me thinking about one in Roulette support aircraft markings! :)
hmm, would that be the new Doritos scheme?
sounds challenging
Postby Ansett A330 » Sat Nov 03, 2018 4:56 pm
That's :
a shocker of a scheme that one.
Even Proposal Number 1 :
was way better than that!
Postby RayS » Sun Nov 04, 2018 4:52 pm
I was thinking of a modified scheme Graeme, something a bit more palatable than the Doritos scheme.
Well, I am very annoyed, I have made some progress photographing along the way. As I was editing the images the program decided to have a hissy fit and deleted most of the 30 images I have taken. So here is an abbreviated update
The landing gear has been assembled, I found the axles to be quite flimsy and managed to break some, replaced with brass rod where applicable
Filled and painted the first coat to find some more filling required. Then I noticed on one the reference images that the RAF A400Ms are being fitted with threat warning receivers on the wingtips, so I just had to mod mine ( so much for an OOP Build)
Still some tidying up to do. I also masked up the base coat and painted the engine intakes and leading edges and APU exhaust.
Postby Ansett A330 » Sun Nov 04, 2018 6:31 pm
Very nice work Ray. Be great to see this one when it's finished - and especially alongside your C-17 (that is when you get to the end of that never ending story!).
Always tempted to get one of these when they are on special (sometimes even cheaper than the 1:144 kit) but pretty sure will "only" get the 1:144 kit one day as not only is the 1:72 kit BIG it looks like a lot of work.
