1/72 Dassault Falcon 900
Postby RayS » Sat Apr 04, 2015 2:15 pm
Some years ago I decided to build a model of all the aircraft I had worked on or flown in the RAAF. At the time there was no kit available of the Falcon 900 in any scale. I had heard of someone using the Hasegawa 1/48 Falcon 10 as a base for the build in 1/72. Turns out it was Fred Harris, Fred was kind enough to send me some copies of the resin engines he cast for his build. So I had a crack at it.
After a lot of cutting of plastic and filler, I got it to this state
Over the years it has got renewed attention as I realised shape issues or figures out how to tackle a problem I had been having with it.
Image To be updated
Image To be updated
So here we are again with renewed interest. I have again pulled it down from the shelf of doom and paid some attention to it.
This time around I am refining the stub wings for the engines an starting to add some detail.
Image To be updated
Image To be updated
So what is left? Scribing some detail into the wings, entry and baggage doors and the engine servicing panels. So I have started to pencil in some of the lines I have to add.
Image To be updated
How far will I get this time, who knows I might even finish it this time around.
Re: 1/72 Dassault Falcon 900
Postby tor lives » Sat Apr 04, 2015 3:08 pm
Very interesting project Ray....you truly are a "modeller's modeller".
You have worked wonders with this "Franken-Falcon". I did it the chicken's way and waited for a resin 1:72 Falcon 900 to be released, which it eventually was by VAMI Models, (in fact I think you supplied me with the RAAF decals for this kit).
I think Broplan also eventually released a 1:72 Falcon 900. Given our shared squadron history, I will be watching this one with much interest.
Postby hrtpaul » Sat Apr 04, 2015 5:10 pm
Bloody hell Ray that's epic. Well done so far :)
Postby Graeme H » Sun Apr 05, 2015 9:01 am
Well, I would never have worked that one out, shows how far Fred looks into stuff, great work so far
Postby F-27pax » Mon Apr 06, 2015 4:11 pm
You're setting us all a very good example. I don't know that I would be bold enough to attempt something so hard.
Postby frediv » Mon Apr 06, 2015 7:17 pm
The cheap version ;)
Inside and outside of the 900. The fuselage pattern consists of two Hasegawa Falcon 10s. In the finished example the fuselage is a fibre glass shell laid up in a plaster mould. Engine intakes are turned and polished aluminium. Slightly modified kit wings.
Postby DesTROYer » Mon Apr 06, 2015 7:28 pm
Still can't figure out how you guys get your seams to disappear so well. I have still so much to learn.
Postby tor lives » Wed Apr 08, 2015 1:52 pm
Nice job Fred!!!
Turned and polished aluminium......now that is impressive!!!
Postby Nicolas_Fantich » Thu Apr 09, 2015 12:32 am
DesTROYer wrote:Still can't figure out how you guys get your seams to disappear so well. I have still so much to learn.
Basic building/construction skills mate. Lots of dry-fitting and alignment of mating parts before application of glue. Use of low viscosity liquid glues helps as fewer 'tell-tale' signs remain after the glue dries. You can't avoid mastery of this if you are going to build credible military/civil/commercial aircraft models, especially those with natural metal and gloss schemes.
Nicolas
On the Bench
1/144 Academy Douglas DC-6B - Adria Airways YU-AFF
1/48 Revell North American P-51D Mustang 'Miss America'
1/72 Airfix North American P-51D (Cavalier) Mustang N51RH
1/72 Airfix North American P-51D Mustang N64CL 'Miss Van Nuys'
Nicolas_Fantich
Postby RayS » Thu Apr 09, 2015 8:20 am
tor lives wrote:Very interesting project Ray....you truly are a "modeller's modeller".
You're correct about the Broplan kit as you sold me yours when you got your resin one :D
This one is a long stalled commission build. I will build the Broplan kit for me later on.
