Australian Airlines B777-476ER - Minicraft Conversion
Postby RayS » Thu Sep 25, 2014 9:14 pm
What a struggle this has been.
Paint has been a pain, decals botched up and waiting for a new set and finally, the engines hung too low so I ripped them off and removed a lot of material to get them to have enough ground clearance.
So shortly I will be rubbing back the whole model and repainting.
Chopping
Joining
Engines by Contrail
Wingtip
First attempt at decaling
Rubbed back
Repainted fuselage
Re: Virgin B777-300ER - Minicraft Conversion
Postby Graeme H » Fri Sep 26, 2014 8:09 am
Looks like you have a bit of a struggle there
Hmm, I guess they are the Contrails engines
Postby RayS » Fri Sep 26, 2014 1:01 pm
Yep, Contrails.
The decal set was also needs the engine bands lengthened to allow for the larger engines. I think they were designed for the kit engines.
Postby Knotty » Fri Sep 26, 2014 7:33 pm
I have one of these to build to Ray , it's currently up to the sanding stage . Like yours every time you do something you find another problem. :roll: good advice on the engine bands ,I might paint mine on I think .
Postby RayS » Sat Sep 27, 2014 9:24 am
No worries Knotty. I have another set of decals coming with longer bands supplied.
Postby Ansett A330 » Tue Mar 20, 2018 2:02 pm
"Bump".
Thanks for the link Ray. Be interesting to see the photos when you rehost and also as it gets finished.
Postby RayS » Tue Mar 20, 2018 7:01 pm
Images updated and a few more added, I had changed the file names since the PB debacle, so I have no idea of what was there before.
There I was thinking the wheels needed work, I dug them out and found I had done a better job the second time around (the old brain cells are not what they used to be)
So it is back to getting the wings and engines repainted now.
Postby Ansett A330 » Tue Mar 20, 2018 10:50 pm
Wow that was quick! Thanks for the photos.
RayS wrote:Chopping
Ah I think I see what was one of the donor kits! A RAAF B777-200 VIP Transport Whiff? Cool.
So what did you end up doing with the "short" bits? A RAAF B777-100 Ultra Long Range Transport Whiff?
Postby RayS » Wed Mar 21, 2018 8:36 am
Rob,
The short bits were made into a 777SP, but that got trashed when I stripped it with the wrong fluid. It was binned some time ago.
I might try it again one day if I can find 2 cheap Minicraft 777s
Postby Ansett A330 » Wed Mar 21, 2018 12:47 pm
RayS wrote:The short bits were made into a 777SP, but that got trashed when I stripped it with the wrong fluid. It was binned some time ago.
I guessed -100 as I think there were details of a proposed "short" 777 in the Norris and Wagner (?) Boeing book.
What fluid caused the trouble? I just usually use Mr Muscle.
RayS wrote:I might try it again one day if I can find 2 cheap Minicraft 777s
Well that could be arranged. What have you got to swop and do the boxings (/Engines) matter?
