CDF S-2A Air Tanker
CDF S-2A Air Tanker
Postby RayS » Mon Jan 12, 2026 3:01 pm
I've been working on this one on and off since the end of last year.
It's the 1/72 Idea S-2A Tracker with Lonestar fire tanker conversion. I also had some rear nacelle parts which I found in the stash and am unsure about their origin.
I have a firebombing tank and other resin for the mods. Decals are from Draw Decals
Here are the resin parts
I realised the rear resin bit needed to be tapered from pictures of Tanker 77
The rear of the nacelles were modifed next.
The assemblies were puttied and cleaned up and attached to the completed wing.
The retractable radome opening was filled with card, I made a template from tape and cut some pieces to a close enough shape, some filling will be needed again.
I also noticed a couple of inlets in the area with are not present on my version so they have been filled from inside with more superglue gel. When they set I backed them with card to make sure they do not end up inside the fuselage when they were filed and sanded down.
The cockpit is basic, I filled sink marks in the seats and reshaped them a bit to get rid of the blockiness of them.
Re: CDF S-2A Air Tanker
Postby RayS » Mon Jan 12, 2026 3:06 pm
The fuselage went together and tank fitted
Wing assembly attached
Clear parts on and sanding done
Ready for paint
Postby RayS » Mon Jan 12, 2026 3:08 pm
First round of paint
And the ancillaries
Ready for final assembly
Postby RayS » Mon Jan 12, 2026 3:22 pm
Decals started, one side almost done
