BPK CRJ-200ER - Kendell Airlines
Postby RayS » Fri Feb 07, 2025 4:11 pm
This is the Big Planes Kits (BPK) CRJ-100 kit in 1/72 scale, we have seen Uros' multiple builds of various CRJs in 1/144 and 1/72 so I though I would have a go at mine.
The kit includes the normal injected parts along with resin and etch parts, as well as a nice window (and paint) mask sheet (not pictured).
I will build this CRJ-100 as a CRJ-200ER, Externally there is no difference to these two aircraft, the engine version being the difference. I will build it as a Kendell Airlines aircraft They were a region operator who were sucked into the then Ansett Airlines vortex in and 90s and did not survive the Ansett collapse in the early 2000s
I made a start yesterday. The office parts were prepped and painted. The instrument panel and coaming are not glued as there are a few decals to to add. I may add seat belts as well
I also made a start on the flying surfaces
And finally the slot was cut out before fitting the cabin window clear strip
I have some choices coming up.
Re: BPK CRJ-200ER - Kendell Airlines
Postby RayS » Fri Feb 07, 2025 5:48 pm
Moving along,
The cockpit is decaled and nose weight added to the nose cone.
Major assemblies (minus engines) taped together
Size wise it is just smaller in length and span than a Gulfstream G-IV
Postby RayS » Sun Feb 09, 2025 9:50 am
Here are the engines parts removed from their pour stubs
And assembled
I then turned to the internals and decided to have a go at building the forward entry/galley area.
Looks like it will fit.
I have now also cut out the entry door, there is no going back now!
Masks applied to the windscreen.
Postby RayS » Thu Feb 13, 2025 2:30 pm
I have been dealing with the cabin windows inserts for the past few days, trying to fair them in. It is a known problem that they sit proud of the fuselage when fitted. I thought I had remediated the issue before gluing but it was not the case.
This was after 3-4 rounds on sanding filling and filing and there were obvious gaps/seams and areas sitting proud.
So today I popped them out and removed all the material behind the window pieces and reglued as flush as I could get it
The cockpit was glued into the nose section
The entry/galley area was painted up and installed
and finally I made up one set of seats (work in progress) as the part of the first row of seats could be seen from the door. I suppose I could have just put a curtain there (which I still might do!)
Postby RayS » Sat Feb 15, 2025 4:17 pm
Well moving along, the cabin windows have been tidied, who knows how they will look under paint again.
The scratch built seats were not installed, I decided on a curtain made of foil instead which folded up somehow when the fuselage parts went together. So there are no seats or curtain now.
I have also brought the major components together with more filling sanding to come
Sanding started and tailplanes test fitted
[url=https://flic.kr/p/2qLQbcq]Image[/url
Postby Uros » Sun Feb 23, 2025 6:07 am
Man, you are realy flying throught this build. Great job so far!
