Dassault Falcon 900
Dassault Falcon 900
Postby RayS » Sun Feb 05, 2023 2:26 pm
I am finally getting on with this one, It's been in the stash for some time (thanks Ray!)
Typical Broplan thin plastic
and detailed instructions
It will be done as a RAAF operated jet
So diving right in!
Some cutting out of bits starting with the flying surfaces
Fuselage
The cockpit, to be tidied up
And testing fuselage pieces together
and finally a tape-up of major parts. I have a bit of adjusting and reinforcing to be going on with as the plastic is very thin compared to other vacs I have built.
Re: Dassault Falcon 900
Postby hrtpaul » Sun Feb 12, 2023 11:54 am
Nice work so far mate :)
Postby Uros » Mon Feb 20, 2023 7:16 am
Nice start! Looking forward to progress.
Postby Bell209 » Mon Feb 20, 2023 3:15 pm
Looks pretty comprehensive for a vacform kit. Nice work so far, Ray.
Rob
Bell209
Postby RayS » Mon Feb 20, 2023 7:14 pm
So back to the Falcon, I have been distracted with C-130 builds for a GB elsewhere.
Cockpit work started to add the clear section (which is not cut down yet).
The start of assembling the cockpit jigsaw...
Test fitting, still needs adjustment
And the nose wheel well doors cut out
Postby RayS » Wed Feb 22, 2023 10:45 am
Got the instrument panel fitted to the cockpit tub, the combing will have to be cut down to make it fit in the fuselage. I have also cut out the transparent section ready to fit when the fuselage goes together.
The wings got a dose of putty as one had a lot of small depressions on the lower surface mainly.
Then I started to sort out the engines, adding some tube lengths to wall in the intake and exhaust sections, I also created the 'S' duct for the number 2 engine from more tubing.
Finally, I removed the Satcom blister from the tip of the tail as the aircraft I am doing did not have it fitted while I was at the squadron. I don't think it got the mod until after being sold off.
Postby RayS » Wed Apr 26, 2023 9:05 am
So moving along with the Falcon, the engines were assembled and puttied. I managed to lose an engine stub wing so I made a new one.
The other sections had been puttied and that was tidied up and more added. I also tinkered with the cockpit pit and instrument panel shroud to make it fit inside the fuselage halves.
As the Broplan plastic is so thin I started to add bulkheads to give it some strength.
And finally, the stub wings were added to the engines.
Postby hrtpaul » Wed Apr 26, 2023 10:02 pm
That's cool as mate. I'd love to try a vacform kit one day. Watching this one with interest :)
Postby RayS » Thu Apr 27, 2023 5:04 pm
Thanks for following Paul.
Did some work reinforcing the fuselage today, as mentioned previously the plastic is very thin and seams will pop very easily.
Some ribs were added and the exhaust section for the No.2 engine so there isn't a huge void visible if you look into the tail pipe.
I had to separate one side of the rear fuselage as it was glued out of alignment.
A test fit shows it goes together nicely at this stage
And the start of the cockpit being cemented in
Postby RayS » Fri Apr 28, 2023 6:17 pm
I'm on a bit of a roll at the moment, the various subcomponents are together.
But first some nose weight!
Major components are glued and the first round of sanding done
The tail group being sorted, I added rub plates to the vertical stab before the horizontal stabs go on, the rub plates are scribed in detail on the vertical stab but stand proud on the actual aircraft
Stabs test fitted, rub plates more noticeable in this shot
A shot of the tail and engine parts
Round 2 of putty applied to the fuselage/wing section, when that is set and sanded then the tail parts will be added. I just remembered the APU exhaust has to be added as well.
