Welsh Models U-4 (Gulfstream G-IV)
Postby RayS » Fri Apr 15, 2022 11:50 am
So adding another kit to the in-work list, lost interest in the HS-125s due to the cutting required for the cheatline decals, I may get back to them one day and finish them off.
It is being built for a the Turning Japanese GB over on BritModeller
I have built a couple of Welsh kits before, this time I hope to manage to master a clear cockpit windscreen!
Here are the box and bits...
A single sheet of parts plus some resin and white metal to keep it interesting
I have outlined the parts in prep for cutting
and the decals
Re: Welsh Models U-4 (Gulfstream G-IV)
Postby hrtpaul » Fri Apr 15, 2022 11:51 pm
Very nice mate. Looking forward to this one :)
Postby tor lives » Sat Apr 16, 2022 7:54 pm
Wow.....great subject Ray!!!
I have the same kit, only mine represents a Gulfstream from the Saudi Royal Flight.
I will be watching this one with great interest.
Postby RayS » Mon Apr 18, 2022 5:11 pm
Onward and upward!
I removed the fuselage and wing parts from the sheet
The fuselage is quite large compared to a Mig21!
Clean up of the bulkhead parts and cockpit floor
Tabs were added to sand the wings
Most of the horizontal stabs have been sanded
I have started to remove the windscreen panels
And finally, the engines went together
Postby hrtpaul » Mon Apr 18, 2022 7:19 pm
That looks nice Ray. I've never built a vacform kit before but I'd like to give it a crack one day. Keep up the great work mate :)
Postby RayS » Sun Apr 24, 2022 1:27 pm
Moving right along...
The instructions give locations of the bulkheads to be installed along the fuselage but the location of the nose one would have it protrude into the nose wheel well if you make the cut out where the scribed lines are.
The scribing of the nose wheel well doors needs to be moved back about 4mm so the fronts align with the bulkhead, the scale diagram included actually shows the doors in the right place.
The cockpit parts were assembled and the cutouts of the nose wheel well were made
I also cut out the doors to the main wells in the wings
After I finished sanding the wings to the correct thickness (well close enough for me anyway) I taped the sub-assemblies together to make sure it was look right.
Postby RayS » Sun Apr 24, 2022 10:43 pm
Some work on the cockpit this arvo, and I think the floor is a tad high. I'm going to have to move that floor down a mil or two
Postby hrtpaul » Tue Apr 26, 2022 7:44 am
This is really cool to watch mate :)
Postby RayS » Thu Apr 28, 2022 10:09 am
Thanks, Paul!
A little more work, I moved the cockpit floor down and have started to play with the engine mounts.
I also boxed in the main gear wells.
Looking at some pictures I will need to add some extra details like the antenna fit and APU exhaust to name a couple of things.
Postby F-27pax » Thu Apr 28, 2022 5:25 pm
You're doing a good job here. I had a go at this kit and made a total mess of it so it ended up in the bin. Yours looks like it will make it through to completion very nicely.
Users browsing this forum: No registered users and 34 guests
