Me and Frank...that 1/72 Carvair
Postby VH-WAL » Wed Jun 04, 2014 12:05 am
This was going to be a straight build of the Formaplane vacuform kit that had been languishing in the stash for several years.... But the plastic is thin brittle and horrible in places and while trying to round out the flattened nacelles using balsa formers I managed to dissolve a large portion of the flimsy plastic with super glue.
Right! so the next phase was to get the red roo DC-6 to DC-4 conversion set and use the nacelles of that to fix the kit wings... nope that is not going to fix the problem!
More headscratching and the current build plan is to use the Heller DC-6 wing converted to DC-4 wing using the red roo conversion and the red roo tailplanes on the Carvair vacform fuselage, of course the shapes and bits don't match so quite a bit of bog sculpting will be required.. (buy shares in milliput), this is going to be character building....
[url=https://flic.kr/p/nxNqmu]Image
[url=https://flic.kr/p/nQhSsR]Image
[url=https://flic.kr/p/nPZQwM]Image
Re: Franken-carvair-stien in 1/72
Postby Tony P » Wed Jun 04, 2014 7:50 am
You are a brave man.!
Postby Adam the Akrodude » Wed Jun 04, 2014 10:42 am
Wally
I salute you and bow low in awe of what you are building! This is one build to watch!
Postby VH-WAL » Wed Jun 11, 2014 11:58 am
anyone got any light weight fibre glass cloth radio modellers use to skin their balsa plane models? I need a small amount to bind in / fair plastic to resin to milliput to vacuform structural joints around the tail plane and wing roots, a half handkerchief size bit of cloth would be more than ample
cheers
wal
Postby Knotty » Wed Jun 11, 2014 7:27 pm
No fibre glass cloth , but I still think you will regret not buying that second Carvair kit :lol: :lol: :lol:
Man you have some work ahead of you !!!! :o :o You are a brave man Wally my friend ..
Postby VH-WAL » Wed Jun 11, 2014 11:42 pm
Evidence of the new found exuberance engendered by Expo, I battled on with "Frank" the Carvair, I glued tabs and doublers under the fuselage joins but it all went pear shaped (well actually saddle back shaped) on the mid top fuselage... never mind .. I SHALL prevail over this POS nothing lots of filler and shaping and sanding wont fix!
Postby Knotty » Thu Jun 12, 2014 8:23 am
Looking good Wally , only 1245 hrs to go ........ :lol: :lol: :lol:
Seriously ,that's coming along nicely .
Re: Me and Frank...that 1/72 Carvair
Postby VH-WAL » Thu Jun 12, 2014 10:17 am
This morning I am like Homer Simpson chasing the runaway roast pork joint.. shouting "It's still good, it's still good" thinking I might have stuffed this up.
Here is pic of the saddle back problem:
two ways of fixing this build up with milliput on top or surgery from bottom of fuselage, cutting through a balsa floor to expose the fuselage top beneath, split the fuselage joint (with it's doubler) open it out a bit and redouble it in it's new position (with gaps) using fibreglass cloth and epoxy resin, don't know which way I'll go yet.
In a Eureka moment I realised why the tail plane fit wasnt real flash.. I was sucked in by the fact that the tail plane root cut out matched the vacuform tailplane fairing, this was entirely coincidental, the fairing was actually too fat and protruded too far so I cut them off..hmm I might have stuffed this I said:
hmm I still can do this, tailplanes joined by a box spar
all I have to do is build some internal bracing structure to hold the tail plane box spar, mount the tailplane, fill the hole and shape a new fairing
Postby Knotty » Thu Jun 12, 2014 11:29 am
Keep at it Wally , looking good so far . You will over come the problems .......one at a time .
Postby VH-WAL » Sun Jun 15, 2014 11:42 pm
After several hours of filling and wet sanding (2 applications of milliput) the saddleback dip that was mostly fixed by splitting the fuselage and pushing a shape up from within is almost gone.. there is a section about 1 cm long which is about 1 mm shallow, I could probably leave it and get away with it but I will skim another layer of milliput over the top and then do the rear bottom fuselage seam. I am happy with this fuselage, it is coming along ok.
Users browsing this forum: Baidu [Spider] and 7 guests
