FINISHED DesTROYer's Zvezda B737-800 QANTAS Retro Roo II
Postby DesTROYer » Sat Sep 15, 2018 8:24 pm
As some of you may be aware, I've been quite busy of late working on another Boeing aircraft, a 1/35 CH-47D, but this evening I started on another new project as well, a Zvezda 1/144 Boeing 737-800 that will be done up as the QANTAS Retro Roo II.
Straight out of the box the kit looks great. The fuselage and wings go together real nice. There are very fine panel lines with I think will come out beautiful under a coat of paint and the flush fitting smooth windows will save a lot of time on filling them and sanding smooth I think.
It’s almost falling together. This is how far I got just after only an hours work.
Back onto the Chinook tomorrow, but I think I'll get some more done on this too.
Re: DesTROYer's 1/144 Zvelda Boeing 737-800 QANTAS Retro Roo
Postby Graeme H » Sun Sep 16, 2018 8:08 am
Great kit, great decal choice, popcorn and beverage ready, deck chair out
Postby DesTROYer » Fri Nov 02, 2018 6:50 pm
OK, Wow. It's been a while since my last update, but that said it has been a while since I did any work on this Retro Roo too, but as work has stalled on the 1/35 Chinook I'm working on as I wait for a part to arrive before I can start on the painting, I've had the opportunity to get some done.
When last we met, I had completed basic assembly of the fuselage and wings. Well over the last few days I've managed to get some paint down and the engines mostly assembled.
Tamiya fine white prima for the white sections, which I will give a light sanding too before applying a tamiya gloss clear coat.
and Tamiya Sky Grey for the Boeing grey sections.
More to follow in the next couple of days.
Postby Ansett A330 » Fri Nov 02, 2018 9:47 pm
Very nice work.
Amazing the difference between the various 737s and the advances in moulding technology over the years :
1969 Airfix 737-200
https://www.scalemates.com/kits/170726- ... boeing-737
1998 Minicraft 737-300
https://www.scalemates.com/kits/123608- ... ng-737-300
1999 Revell 737-800
https://www.scalemates.com/kits/148731- ... ng-737-800
2017 Zvezda 737-800
https://www.scalemates.com/kits/1016987 ... ng-737-800
which with new parts brings us up to date and becomes :
2018 Zvezda 737-8 MAX
https://www.scalemates.com/kits/1114131 ... -737-8-max
Re: DesTROYer's 1/144 Zvezda Boeing 737-800 QANTAS Retro Roo
Postby DesTROYer » Sun Nov 04, 2018 3:17 pm
Yesterday and today have been most productive. Last night after dinner I was able to put down a gloss coat to Tamiya clear, which allowed me this morning to begin decals.
Though made for the Revell 737-800, using the Hawkeye set on the Zvezda kit works pretty well. On this side I started at the rear and worked my way forward. The length is right and the windows line up pretty well, but where the cutaway for the cockpit windows ends up is a little bit off.In hindsight I should have started there and finished at the rear. A bit of playing around and I got it to work out in the end.
As with the other side, I cut up the long cheat line into inch long pieces, as I found that last time, this time however I did start at the front of the plane and worked my way back and got a much better fit around the windscreen. The Anti-glare panel decal covers up the join between the two pieces.
Keeping at it with a crappy B-Grade Movie on in the back ground, I managed to get through all of the decals in a couple of hours, even managing to get the engines and tail planes glued in place.
I still need to install the lights in the wings, seal the decals with another gloss coat and paint up a flying Rat logo on the base, but its getting closer to finished.
It already looks pretty good beside Retro Roo James Strong, if I do say so myself.
FINISHED DesTROYer's 1/144 Zvezda B737-800 QANTAS Retro Roo
Postby DesTROYer » Mon Nov 05, 2018 1:19 pm
Got back into it this morning starting off with the display stand. Using the Silhouette cutter I made up some masks and after spraying a white base on the stand I applied the mask and set to work putting the colours down.
Some minor touch ups were required, but it came out just as I had hoped.
Then after a clear coat was applied to both the stand and the model, were were done. So I now present to you my finished Boeing 737-800 Retro Roo II. Zvezda 1/144 737-800 kit, Hawkeye decals, Tamiya paints.
Looks pretty good next to its stable mate.
Re: FINISHED DesTROYer's Zvezda B737-800 QANTAS Retro Roo II
Postby Graeme H » Mon Nov 05, 2018 4:49 pm
very nice Troy, we will make an airliner modeller of you yet
Postby DesTROYer » Mon Nov 05, 2018 6:28 pm
Graeme H wrote:very nice Troy, we will make an airliner modeller of you yet
lol, that's three Airliners I've built now. I guess there is no more denying I am one anymore.
Postby tor lives » Mon Nov 05, 2018 9:06 pm
Great job young Troy, they all look magnificent!!! .....we all knew you were one of "us" :D
Postby RayS » Tue Nov 06, 2018 8:34 am
Nicely done young Troy
So what's next?
More QANTAS, you know you need a Dreamliner in the collection now!
Users browsing this forum: Baidu [Spider] and 17 guests
