Ray'S B737-838 VH-VXQ
Postby RayS » Fri Aug 12, 2016 7:24 pm
So over on Britmodeller there is a very active Airliner GB in progress (61 build threads so far!)... I am one of the GB moderators over there.
To be honest I am amazed at the number and variety of entries and we already have 3 builds finished (with a start on the first of the month).
Here is my first build a Revell B737-800
It is the original release without winglets but its not an issue as I have the Contrails replacement wing (with winglets) and a set of replacement engines.
I also have a set of Braz winglets, just in case.
On to the decals, I will be using the Hawkeye sheet for Retro Roo II
Re: Ray'S B737-838 VH-VXQ
Postby RayS » Fri Aug 12, 2016 7:26 pm
Started some clean up of the resin, boy did it need it too.
A test fit of the wing...
Holy batwings Batman!
Looks like some hot water treatment required!....
After some hot and cold water applied the wings look a lot better
I started to clean up the so-called B737NG Contrails engines and gave up on them. They look identical in shape to the kit engines and look like blobs of resin, So I will mod the kit engines instead.
Postby RayS » Fri Aug 12, 2016 7:30 pm
The work continues
Cabin windows filled
Nose weight added (just in case for plan B)
Internal mount created
Test fit of the bits so far
Postby RayS » Fri Aug 12, 2016 7:33 pm
It turns out the Contrails set had 2 LH winglets, so I broke out one of the Braz winglets and started reshaping it and extending the Contrails one...
I also started some puttying
Postby RayS » Fri Aug 12, 2016 7:36 pm
Been filling and sanding the fuselage seams for most of the night. Pretty happy with them
Also installed the winglets
Glued the wing the fuselage after a lot of test fitting
Only to have the superglue grab and dry very before I could get the forward section in place. Now I have a large gap I need to fill.
I have hit it with acetone but I can't budge it so it looks like I will have to fill and sand to get rid of that step.
Postby DesTROYer » Fri Aug 12, 2016 9:23 pm
See, this is what I'm talking about. Great work so far, Ray. Keep it up.
Postby scotty100368 » Fri Aug 12, 2016 9:31 pm
Ray, try some of this:
It's usually sold next to the CA glues.
Scott.
Postby hrtpaul » Sat Aug 13, 2016 2:39 pm
Looks great Ray. I wanna be involved in that GB but I'm not sure how I'll go. Keep up the great work mate :) :) :) :)
Postby RayS » Wed Aug 17, 2016 11:09 am
Some filling
and after some sanding and base coat applied, still found some seams that still need attention
Postby DesTROYer » Wed Aug 17, 2016 12:21 pm
Mate, I hate sanding. That much filler would make me want to bin the kit. :)
