A rarity....Marui 1/36 Fuji Aero Subaru
Re: A rarity....Marui 1/36 Fuji Aero Subaru
Postby Adam the Akrodude » Thu Nov 03, 2016 11:32 am
Coming along well Damo!
Postby Cap'n Wannabe » Fri Nov 04, 2016 4:02 pm
Bloody photobucket! Down for maintenance, so I can't post any pics!
Still, I've decided on this one not to wire it up, and I probably won't wire up my other one either, because adding the motor means there's practically no room for nose weight, and this baby needs a lot! 40 small sinkers in the engine bay...
Anyhow, I've added the weight, and started buttoning her up. Pics to follow once photobucket gets their shite together..
Postby Cap'n Wannabe » Sat Nov 05, 2016 7:53 pm
Finally photobucket's back up..
I spent a little bit of time today figuring out how to glue the top of the cabin, which wouldn't align naturally. It had a bit of a gap at the seam, and the right side was slightly higher than the left side. I tried taping it all together and clamping it, none of which worked. In the end, I aligned them by hand and judiciously super-glued them together before reinforcing the join with liquid cement. The canopy bow is a bit different given it's so small. I'm thinking I'll have to glue in the windscreen and carefully glue the bow to the back of the screen. *sigh*
Anyhow, on to the photos..
In this one, you can see the amount of nose weight I've added. Each side has 20 small sinkers and a huge wad of Blutac.
Here, you can see the large gap and misalignment of the top of the cabin..
All glued together now...I still have to add the front of the cowl, and the battery hatch underneath.
Looking forward to the IP. The tape's really come up well simulating carpet!
Looking back into the cabin..
Postby Cap'n Wannabe » Sun Nov 06, 2016 8:05 am
Well, I think I've screwed up...
I went to dry fit the windscreen, and found a sizeable gap at the top of the screen. At first I thought the windscreen was short shot, but the gap looks too even for that. Then I remembered some flash I'd sanded from the frame ages ago....only it wasn't flash! How to fix, how to fix....
Postby Adam the Akrodude » Sun Nov 06, 2016 10:20 am
Easy - just fill with a bit of plastic card - undo/redo that "flash" - no biggy, or as one US POTUS contender says "biggly"! :D
Postby hrtpaul » Sun Nov 06, 2016 8:32 pm
Looking good Damo :)
Postby Cap'n Wannabe » Wed Nov 16, 2016 2:50 pm
So I've reluctantly glued the windscreen in place. When I dry fit it, it seemed to fit OK, but now it's bloody awful. I'm going to have to remove it and ponder the situation a little - possibly make a new screen, which will be a first for me. I only hope the rest of the windows fit better!
Postby Adam the Akrodude » Wed Nov 16, 2016 4:27 pm
Can you file/sand the windscreen down and then polish it? That to me sounds less work than say vacu-forming a new one.
Postby Cap'n Wannabe » Wed Nov 16, 2016 5:05 pm
Adam the Akrodude wrote:Can you file/sand the windscreen down and then polish it? That to me sounds less work than say vacu-forming a new one.
Nope....the windscreen's a tad too small!
Postby Adam the Akrodude » Wed Nov 16, 2016 7:15 pm
Use it as a master to vac-form another then.
