Dornier 228 Finnish Border Guard
Re: Dornier 228 Finnish Border Guard
Postby TheChronicOne » Fri Jan 31, 2020 4:03 pm
"The chop" "The extension" These are phrases I can totally get behind. Looking damn good to me so far..... keep going and don't slow down. 8-)
Postby RayS » Sun Feb 02, 2020 4:30 pm
Time for some boxing ...
Looks very agricultural at his stage before removing the excess plastic
After removing a lot of the excess plastic it was time to create new windows and fill those in the wrong locations.
I ended up popping the existing clear parts out so I could remove the windows that will be filled and relocate them to the new locations. I am still short a couple that I will have to make from CD case clear plastic
Postby TheChronicOne » Tue Feb 04, 2020 12:57 pm
This is great........ taking notes. I dig the square rod! Going to have to pick some up.
I just remembered that I saw a Trislander build recently where the feller extended the fuselage and a couple other things. For interest:
https://www.whatifmodellers.com/index.php?topic=46707.0
"Square fuselage" ....
Postby RayS » Tue Feb 04, 2020 1:23 pm
Cheers Brad,
Interesting Trislander build there it looks like it started out as two Twin Otter kits!
Postby TheChronicOne » Wed Feb 05, 2020 1:10 pm
Right you are! I goofed up. I forgot how it started. :lol: Defintely has the Trislander look but not a Trislander. Memory gets hazy after awhile.
Postby RayS » Sat Feb 08, 2020 10:11 am
It is a great what-if anyway, wish I had thought of it :)
Postby RayS » Thu Feb 13, 2020 8:52 pm
A little bit of sanding done (twice) on the Dornier with another round to follow
and with a guest correct length fuselage (thanks Scotty!) for comparison (what to do with a kit that does not need mods?). Got the length pretty much spot on with the stretched -100
and another test fit of wings and engines
Postby Ansett A330 » Fri Feb 14, 2020 9:54 pm
Absolutely amazing Raymundo.
This would be like making a Lincoln from a Lancaster if a Lincoln kit was available (come on Airfix you know you want to do it!).
I’m on the road at the moment (well was actually on a roof this morning!) but hopefully Graeme might be able to post a couple of (bad) photos I took of one of the Toll -200’s at EMD which show just how much anhedral the wings on one of these have. Couldn’t find a good head on shot that I know I have somewhere but the ones I sent should give you an idea as it looks quite massive in real life.
Postby RayS » Mon Mar 02, 2020 11:19 am
I have been putting this on off for a while as I had a few easier builds to go on with. Now they are nearing completion I decided to get this one back on track.
The main thing putting me off was making the search radar. I had been thinking about how I was going to make the shape up, initially I was going to use laminated plastic sheet then I recall picking up some green stuff some time ago. I dived into the supplies and found it. First I made base template out of sheet styrene and then mixed the 2 part putty together.  I shaped toteh roughly what is should look like and then left it to set. At this time I also made up the two SLAR antennas
Next the radome was sanded and filed down to refine the shape and SLAR also tidied up
A test fit showed the radome was too deep so I removed the base plate template
At this time I started to add the mounting fixtures for the SLAR and the turret that lives on one of the main landing gear sponsons
And then time to a test fit is the parts, the search radar radome received a couple of more sanding sessions to reduce the depth again as I thought it was still too lager
I was glad to find the kit included some of the antennas I was planning to scratch build so that will speed things up. I need to putty in the windscreen and maks off the clear parts in prep for priming soon.
That's all for now
Postby RayS » Wed Mar 04, 2020 4:12 pm
A little more scratch building of the antennas and IR turret head fitted
