Dassault Falcon 900
Re: Dassault Falcon 900
Postby hrtpaul » Sun Apr 30, 2023 1:02 pm
Very nice so far mate :)
Postby RayS » Sun Apr 30, 2023 10:10 pm
It is slowly coming together. The no.2 intake/vertical stab is glued in place, filled, and primed.
Looks like I ned to do some patching on the rear fuselage, the thin plastic has struck!
Some paint is in the cockpit, no color callouts in the instructions but I know it was a bunch of greys
The seats and columns are painted and ready to go in.
The next job after they go in (and the consoles and inst panel are detailed) is to add the clear section
Postby Uros » Sat May 06, 2023 4:44 am
Looking good Ray. It's coming together nicely.
Postby RayS » Tue May 09, 2023 11:07 pm
Some work on the cockpit was done the seats were modded with armrests and repainted
I also installed the control columns and repainted the cockpit floor, finally, the windscreen section was masked and trimmed to fit the opening.
When I finish repainting the rest of the cockpit and the setas go it then the windscreen section will be glued into place
Postby RayS » Thu May 11, 2023 10:07 am
Seats in and clear part glued in, I have started to fair it in now. and it should be ready for another primer coat later today
Postby RayS » Sun May 14, 2023 10:03 pm
Fairing in the clear part is taking longer than planned, still, a little filling and sanding to go after this primer session. I have also added the no1 and 3 engines
Postby hrtpaul » Mon May 15, 2023 6:13 pm
It's looking more and more like a jet. Nice work :)
Postby RayS » Wed May 24, 2023 7:00 pm
It certainly is Paul,
I have been tardy with this build (and others), we have been house hunting for the past month.
I finally sorted out the front end
And the gear parts were fitted
And finally, I started to clean up the final parts for assembly, just a little flash
