1/72 Vickers Viscount 839
Re: 1/72 Vickers Viscount 839
Postby RayS » Tue Mar 09, 2021 4:15 am
Fuzznoggin wrote:A lot of work Ray! You've nailed this one. Fine job!
Thanks Jack, hope to have it finished soon
Postby F-27pax » Tue Mar 09, 2021 7:05 am
I'm impressed. Talk about making a silk purse our of a sow's ear.
Postby RayS » Wed Mar 10, 2021 4:49 pm
Some more assembly and painting, props still need to be finished. I had to add a shim behind the prop else it would rub on the cowl
I think I should have lengthened the gear rather than cutting the nose strut down. The nose doors look over size so I might trim them down a tad
And finally some decaling started
I am still working on the slipper tanks when when filled will ned some fairing in and touch up paint. I will leave the rest of the decals until after they go on and are finished. The anti glare panel on the nose will need painting as well
Postby RayS » Wed Mar 24, 2021 12:09 pm
Until I had a minor disaster with the decals after I masked over them to paint the antiglare panel.
I tried to match with paint which did not go well, so Pete at Hawkeye to the rescue with a replacement sheet. These new decals were done on a new printer so the colours for the cheat line are a touch different. I could not just cut a section out to replace the damaged area.
Off with the cheat lines, so some masking tape on the cheatline decals took them off nicely, I also removed one of the wing roundels as I had placed it too far outboard.
The slipper tanks were fitted...
and faired in with PPP which was tidied up and painted.
Masking of the nose after the decal/paint stuff up.
And finally masking off and ready for cheatline decals to go back on.
Postby RayS » Wed Mar 24, 2021 8:06 pm
Calling it done
Postby oz rb fan » Thu Mar 25, 2021 11:46 am
looks great Ray
Postby hrtpaul » Sun Apr 11, 2021 5:52 pm
Very nice man :)
Postby F-27pax » Tue Apr 20, 2021 6:28 pm
Outstanding. Those Mach 2 kits are almost impossible to make look good, but you did.
