1/72 Antonov AN-10
Re: 1/72 Antonov AN-10
Postby RayS » Thu Nov 05, 2020 8:55 am
I went over all the areas I had rough sanded and tidied them up with some 400 grit paper to get rid of the grooves from the 180 grit I used previously.
After regluing the LH MLG assembly together again (this time it will not come apart) I added the little fiddly bits, starting with the tail skid and lower ventral fin
Next were some antennas up front, you see that dome on the chin, I was supposed to shove 40grams of weight in that, I suspect it would not have fit, fortunately it was put in the fuselage and as I recall about 150 went in.
and finally I put the wheels together
So next I will re prime the seems and it will be time for the paintwork
Postby VH-WAL » Thu Nov 05, 2020 4:07 pm
yeah I want one of those!
Postby RayS » Fri Nov 06, 2020 6:02 am
With the way you handle those vacform kits Wal you won't have any issue beating this into shape
