1/144 Ray'S 737-26Z Adv Challenge Build - RTAF
Re: 1/144 Ray'S 737-26Z Adv Challenge Build - RTAF
Postby TheChronicOne » Fri Jul 27, 2018 10:19 am
Lovin the work here. The process and pictures are inspiring... I want to start one of mine really bad now from seeing your excellent work. :)
Postby RayS » Sun Sep 02, 2018 9:16 am
I am bogged down trying to get a nice white base coat on this one.
I have painted and stripped it 3 times now, the oven cleaner has been eating the putty away so I will have to refill various areas before the next attempt at painting.
Back to the bench
Postby hrtpaul » Mon Sep 03, 2018 8:00 pm
Have you tried Tamiya white primer? A few coats of it is what I used on mine. With a quick sand with 4000 grit Micromesh it comes up fantastic.
Even better after 2 coats of One Go.
Postby RayS » Tue Sep 04, 2018 10:33 am
Yep, I am just too heavy-handed when applying it. Got some more yesterday. I am going to layer it on lightly this time around and stop trying to rush.
I stripped another 3 models back on the weekend due to the same issue, MD80, B727 and C-17.
Postby hrtpaul » Tue Sep 04, 2018 9:18 pm
On my other 737 I CBF'd sanding the belly anymore so i laid down a very thick coat using it like spray putty. Worked a treat. But yeah light coats are definitely the go :)
Postby RayS » Sun May 12, 2019 9:17 pm
Wow, I did not realise I had not updated this thread in such a long time.
I think I decided I would use the Braz engines from my last 737 build
Image144_Airfix_737_15 by Ray Seppala, on Flickr
I have painted and stripped this one a couple of times now.
paint and masking on
an now it is gone and I have managed to add some antennas to this one as well
Tha's it for now
Postby hrtpaul » Tue May 14, 2019 7:36 pm
Coming along nicely there Ray :)
Postby TheChronicOne » Wed May 15, 2019 4:39 am
Good progress!! I sympathize on many points. Even tiny progress is good, though, so as long as we're going forward and not backward, It's a plus I guess. I'm moving slow on mine, as well.
Postby Graeme H » Wed May 15, 2019 7:32 am
Keep on keeping on Ray, we know you can do it
Postby RayS » Wed May 15, 2019 6:01 pm
Thanks guys, it seems I am going sideways on this one, I hit it with white primer and noticed a reaction to some paint dregs on it, so out with the sandpaper yet again.
Users browsing this forum: No registered users and 39 guests
